no cat in nc?
Old Nov 16, 2013 | 07:03 PM
mikey8494's Avatar
Car: 1986 camaro iroc z
Axle/Gears: stock
no cat in nc?
i live in easter north carolina and they have inspections here and i was wondering would i pass inspection if i removed it off my car here in nc or not?
Old Nov 16, 2013 | 10:29 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: no cat in nc?
No, without a cat, even if you managed to pass the sniffer test you wouldn't pass the visual.
Why do you want to take the Cat off anyway? You won't gain anything by removing it.
Old Nov 17, 2013 | 04:46 AM
stroked_n_blown's Avatar
Car: '92 Camaro RS
Engine: 305 TBI
Transmission: Richmond Gear street 5 speed
Re: no cat in nc?
Sniffer test shouldn't be an issue; only do visual check in Eastern NC as far as I know ( at least in Cumberland County anyway).
Old Nov 17, 2013 | 11:37 AM
Re: no cat in nc?
Since cats are SO CHEEEEEEEEEEEEEEEEEEEEEEP, and modern ones don't create any significant restriction anyway, there's no reason to take it off if it works; and no reason NOT to replace it if it's messed up.
Old Nov 17, 2013 | 03:29 PM
mikey8494's Avatar
Axle/Gears: stock
Re: no cat in nc?
im wanting to get a bit better flow through my system and a better sound out of my v6
Old Nov 17, 2013 | 06:39 PM
Re: no cat in nc?
The cat isn't the limit.
2 more cylinders, would help. Messing with the cat, won't.
Old Nov 17, 2013 | 09:10 PM
mikey8494's Avatar
Axle/Gears: stock
Re: no cat in nc?
face palms. look not everyone can afford the gass bill of a v 8 and being 19 a v8 would make my insurance skyrocket
Old Nov 17, 2013 | 09:31 PM
Re: no cat in nc?
Then learn to enjoy the "sound" you're stuck with.
A 6-cyl sounds like .... a 6-cyl.
A LOUD 6-cyl sounds like .... any other 6-cyl, except you have to be even farther away from it to keep from being annoyed by it. It's even worse than a loud V8 non-performance exhaust. (think, 305 TBI pickup truck w straight pipes and glasspacks)
Trust me, NOBODY is going to be "impressed" by any kind of "sound" you can get out of a 6-cyl. (except maybe Honduhhh owners with 4-cyls) Just make it work the best that it can, without regard to "sound", (don't advertise that you're economizing on insurance) and bide your time until you can step up into the next higher league.
Old Nov 17, 2013 | 09:47 PM
kmcn47's Avatar
Car: 84 Trans Am, 84 Fiero, 86 944
Engine: 5.0, 2.5, 2.5
Transmission: 5spd
Re: no cat in nc?
insurance isn't so bad with a v8 at 19, you've got to remember that the insurance company is gonna look at how old that car is, because of its age they wont give you much for it if its totaled so how could they possibly make you may them so much? and blunt though he may be sofa is right. there isn't any reason to remove your cat. you complain about v8 gas mileage well what do you think will happen to yours if you remove the cat? its gonna get worse. and the car will sound worse, not better.
Old Nov 17, 2013 | 10:02 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Re: no cat in nc?
I wouldn't say that's entirely true. There is a guy here where I live driving a sky blue 1997 Supra with a Cammed v-6 that sounds evil at idle, with no "fart can" on it. It just thumpity-thumps...then the howl of the turbo kicks in when he gets on it. But, you can get a V6 to sound "Good", but it won't touch the rumble of a V8.
Old Nov 18, 2013 | 09:44 AM
mikey8494's Avatar
Axle/Gears: stock
Re: no cat in nc?
well if anyone has a v8 lieing around that they are gona just give to me ... im open to that
Old Nov 18, 2013 | 03:40 PM
mikegolz1987's Avatar
Car: 1991 rs
Engine: 305 tbi
Transmission: 700 r
Axle/Gears: 7.5
Re: no cat in nc?
the reason I removed my cat was to replace with a full new set up flow master save your money and don't half *** It and if just gotta take it off then yes to question it will pass in the state of n.c. its old enough to just have to pass a safety test lights horn etc but if for some reason the v6 lights up check light you will have to find a way to get some o2 cheaters in there
Old Nov 18, 2013 | 04:18 PM
mikey8494's Avatar
Axle/Gears: stock
Re: no cat in nc?
weird thing is the o2 sensor cable came off and isnt hookedu p but the check engine light has never come on but im gona try to save up get a motor and spend time slowly building it with the best parts
Old Nov 18, 2013 | 05:44 PM
mikey8494's Avatar
Axle/Gears: stock
Re: no cat in nc?
and i find out i will never have the money for a shortblock and heads i have no job and most employers dont want to hire me aroudn here cuz of my lack of experience and my bipolar im trying to get into college with grants i wish someone had one justl ieing around i could come pick up so i can slowly rebuild it....
Old Nov 18, 2013 | 07:32 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Re: no cat in nc?
Set your sights on what's reasonable as a job for you, go to school at night. What I did until I joined the military.
You can find a good used block in a junk yard for probably less than $300.00, complete with accessories and if your lucky, all the wiring.
Old Nov 18, 2013 | 07:33 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
Re: no cat in nc?
if you are determined to pollute our air you can unbolt the cat back system and knock out the cats innards with a pipe and hammer.
Old Nov 18, 2013 | 07:35 PM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
Re: no cat in nc?
Originally Posted by Ozz1967
...sky blue 1997 Supra with a Cammed v-6 ... howl of the turbo kicks in. But, you can get a V6 to sound "Good", but it won't touch the rumble of a V8.
Hate to tell you, the Supra has a Straight-6 cylinder (even fire), versus the chebby odd-fire v-6. There is no way to make one sound anything like the other. Additionally, the turbo provides extra muffling in the exhaust, opposite of what you want to do by removing the cat.
x2 on SofaKingdom's disdain for the sound of a v-6, especially loud ones.
Old Nov 18, 2013 | 07:51 PM
mikey8494's Avatar
Axle/Gears: stock
Re: no cat in nc?
is a high flow cat better or pretty much the same
Old Nov 18, 2013 | 07:52 PM
mikey8494's Avatar
Axle/Gears: stock
Re: no cat in nc?
either way im gona keep the cat and save for a tpi i real want a tpi
Old Nov 19, 2013 | 08:10 AM
Car: 1991 rs
Engine: 305 tbi
Transmission: 700 r
Axle/Gears: 7.5
Re: no cat in nc?
here in Winston-Salem n.c. I found a lot of 350's for 200 to 300 including trans now finding tpi around here is a needle in a hay stack but possible if go carb 350 itll be easier to set up my opinion I grew up around Camaros with my uncle and we would swap engines all the time but we stuck with carbed engines and there was alittle wiring involved but not as much tinkering ecu and wiring wize as you would think now I was young and a kid but I do remember it didn't take as much as you would think a carbed 350 don't need a lot to run they are one of the most reliable motors chevy made and you can find them anywere that's why there so cheap
Old Nov 19, 2013 | 11:40 AM
mikey8494's Avatar
Axle/Gears: stock
Re: no cat in nc?
ok il lgo with carbs
Old Nov 19, 2013 | 09:04 PM
Re: no cat in nc?
Yeah, that'll get you through inspection, for sure....
Old Nov 20, 2013 | 11:50 AM
mikey8494's Avatar
Axle/Gears: stock
Re: no cat in nc?
what do you mean i just said im gona keep my cat and go with a carbed 350 how is that gona fail inspection
Old Nov 20, 2013 | 12:10 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Re: no cat in nc?
Because a carbed motor will fail both the visual and sniffer test if your car was originally fuel injected. SInce it's been indicated they do visual where you live, then you will fail the emissions test.
You can go to "A friend of a friend"...one of those guys who's shop passes people because he knows them, but they risk being fined upwards of $25000 for illegally passing smog tests for people.
Old Nov 20, 2013 | 12:49 PM
mikey8494's Avatar
Axle/Gears: stock
Re: no cat in nc?
well for one if you live here in north carolina they dont care if you have a carbed motor or a fuel injected one as long as it works properly and nothings tampered wirh and 2 they dont do sniffing tests on cars older than 1996 just a saftey inspection and a visual look over the cat etc.
Old Nov 20, 2013 | 12:52 PM
mikey8494's Avatar
Axle/Gears: stock
Re: no cat in nc?
either way im keeping my v6 andi m gona work to get everythingi posibly can out of it so drop it
Old Nov 20, 2013 | 03:04 PM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Re: no cat in nc?
Nothing tampered with... like replacing fuel injection with a carb.
Not trying to bust your *****, just want to help you avoid headaches.
Joe
Old Nov 20, 2013 | 03:07 PM
mikey8494's Avatar
Axle/Gears: stock
Re: no cat in nc?
im keeping my v6 because i want to keep some originality but im gona do some seriouse modding to get the most hp and tq out of it
Old Nov 21, 2013 | 10:54 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: no cat in nc?
If you dont mind the work, converting the car to a manual trans will make it a lot more.fun to drive even with just the stock v6.
To comment on an earlier detail, fwiw the 305 tbi cars get better gas milage than tbe v6 cars.
Old Nov 21, 2013 | 04:11 PM
mikey8494's Avatar
Axle/Gears: stock
Re: no cat in nc?
wish i had the money how easy is it to convert to a 6 speed
Old Nov 21, 2013 | 04:13 PM
kmcn47's Avatar
Transmission: 5spd
Re: no cat in nc?
from an auto, its a ****ing pain. read all http://www.skulte.com/T56.html
Old Sep 24, 2019 | 11:32 AM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Re: no cat in nc?
I guess the OPs "ditching of the emssion controls" back them sure made it able "to maintain the vehicle with ease".
I bet it sure made it easier huh?
I guess its a good warning what commie-fornia and commie-raro rules may be coming to your state
soon if the eco-weenies and libtards cry louder and longer~
So its wise to leave your emissions stuff in place (poss. disabled) to eliminate future problems
and finding and replacing them!
Old Nov 18, 2019 | 07:00 PM
Abubaca's Avatar
Re: no cat in nc?
Here in NC you do have to pass the visual, as has been established. It's likely no one will care if there are cats, and no one will care what engine is in there, BUT.....technically.....it's supposed to be in there and original, unless you have all the proper emissions crap etc. etc. ...many mom and pop places just want the car on the property, though they don't even actually inspect it. But again, that's not the "law" per se, so it's up to you what you wanna risk with parts that aren't legal.
....but removing the cat won't do you any favors. Won't affect the sound too much, won't improve flow on a V6. Maybe it's original, and maybe it'd help, but even then....I'd go back with a modern high flow cat. They flow VERY well.
Advice? -buy one of the Motorbooks series books on building a small block chevy, or read Lingenfelter's book on modding small block chevy's. (or Both). SOOOO much valuable, timeless info in those books. Lingenfelter's book references some older part numbers that might not be ideal nowadays, but all the principals and theories are every bit as relevant today as they were back then.
Old Nov 18, 2019 | 08:25 PM
WildCard600's Avatar
Car: 1989 Trans Am
Engine: sp357
Transmission: TKX
Re: no cat in nc?
Psst... Thread is from 2013 and OP hasn't logged in since 2016.
Last Activity: 12-02-2016 08:40 PM
Old Nov 19, 2019 | 07:25 AM
Abubaca's Avatar
Re: no cat in nc?
Yep. ...I just saw NC and that it had been recently replied to. Didn't even check dates.
LT1Formula
Oct 8, 2015 08:34 PM
jaridjohn
Oct 5, 2015 07:01 AM
