Headers needed.
Car: 82 Z28
Engine: 370 ci.
Transmission: M 20 4 speed
Axle/Gears: stock open 3.43
Headers needed.
I'm rebuilding the engine in my 82 z28. It should be putting out about 500 hp. The headers that are on the car have the collectors cut off and pipe welded in. The driver side goes between the front of the oil pan and the front cross member or cradle. The pipe is extremely close to the oil pan and I don't like it at all. I do run a oil temp gauge.
What I am looking for is the best option for headers so as not to restrict the output of the engine. I have a sbc and super t10 in it so I'm not sure if any ypipe will work?I probably wont find one for that combo. I can fab one up later. I would like to get the engine and headers installed as soon as it comes back from the shop.
Any info from the resident experts would be appreciated.
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: Headers needed.
Being that you have a Manual in the car, you can fit a set of true dual's in the car if you want. I'd recommend looking at the ones Dyno Don offers, they are specifically made to fit our cars
If you had an auto I'd recommend either the Dyno Don or Hooker 2055 models as both are shorty headers with included Y-pipe built to fit our cars.
The last question is, are you someplace that needs emissions testing? If you are, having true duals on your car may fail the visual inspection portion of the inspection.
Car: 82 Z28
Engine: 370 ci.
Re: Headers needed.
No I don't need emission testing. With the duals do you run them into a single dual inlet muffler or dump them in front of the axle? Can you get both pipes over the rear end?
I don't want it loud or the dreaded drone so any advice on mufflers would be appreciated also. Right now it has a stock sounding three inch exhaust, I like it low key. Maybe a little throatier than stock but not even approaching obnoxious is what I'm looking for if that helps with suggestions.
Every time I read Dyno Don on here I think of Mr. Nicholson. It's not the same Don is it?
Car: 82 Z28
Engine: 370 ci.
Re: Headers needed.
https://sdparts.com/details/doug-tho...aders/dhcd3321. Jegs will price match
Car: 91 Firebird
Engine: Turbo 355
Axle/Gears: 3.73:1 7.625" 10 Bolt
Re: Headers needed.
I have my Hooker Super Comps 2210 Ceramic coated listed in the classified section. If you're interested.
Car: 1983 Z28
Engine: 385 Fastburn
Re: Headers needed.
Depends on the size. Mine are true dual 2.5" dumped just before the axle. I was told getting them over the rear would be a pain.
redformula88
Oct 14, 2015 06:08 PM
Chad Speier
Sep 24, 2015 12:32 PM
[GA] Shorty headers
Night rider327
Sep 16, 2015 02:20 AM
