Sewer pipe: 5 inch single
Old Jul 31, 2014 | 07:32 AM
  #51
sootie007's Avatar
Car: 91 RS VERT
Engine: 305 9.67 2.02 58 cc 282 480 108 LC
Axle/Gears: 4.11 POSI
Re: Sewer pipe: 5 inch single
Your car is a phenom ! Be safe out there .
Old Jul 31, 2014 | 07:57 PM
  #52
Sojer's Avatar
Car: 1987 IROC-Z red t-top
Engine: Nothing much
Transmission: I wish t56
Axle/Gears: 9bolt 3.27 4sale
What size tire u run orr89rocz
Old Aug 4, 2014 | 12:29 PM
  #53
antman89iroc's Avatar
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
Orr that is crazy fast and seemed fairly well under control. Good job so far not just with the exhaust but everything. Your goals are a bit higher than mine- like 3x more power- but it is awesome. I mean I'm in awe!
BTW what rear dif are you running?
Old Sep 4, 2014 | 10:29 AM
  #54
David 91RS/Z28's Avatar
Every so often I visit the board only to find Mr. Orr doing further upgrades to that already insane ride! LOL Just bad ***!
Old Sep 4, 2014 | 11:51 AM
  #55
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Thanks guys! Its never ending! Soon to be on 30 psi boost!! Should be over 1200 whp if tranny holds. Its impossible to drive on street at 18 psi and higher, it just spins but anything less than 15 is boring lol
I run 305/35/19 mickey et street radial 2's as my street tire. Sticky! But no match for over 750whp.
Other setup is 295/55/15 micket et street radials. Work ok so far but still spins on street on higher boost. Track seems ok but need more seat time to dial in suspension.
I run a strange 12 bolt with detroit tru trac diff. 3.42 gear at the moment. I want 3.08-3.23's tho
Old Sep 4, 2014 | 05:05 PM
  #56
I can only imagine..
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
gord327
Sep 29, 2015 10:18 PM
