Advice for a slip-fit cat that won't slip on?
Old Apr 13, 2014 | 05:59 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Got a new cat in the hopes I'll get better emissions readings, but I had to hammer the old one off with a rubber mallet and the new is the same size as the old one but won't slip on. Tried using a rubber mallet but it's just not wanting to go. Total pain in the butt. Any advice?
Bigger mallet?
Old Apr 13, 2014 | 06:24 PM
1991sleeper's Avatar
Car: 1991 firebird
Engine: TBI 305 (built)
Axle/Gears: 4.10
Bigger mallet?
Take a crescent wrench n flare the end out
91' bird 305 TBI T-5, trick flow heads, 4.10 gears, full UMI setup, track times coming soon!
Car: 1991 firebird
Axle/Gears: 4.10
Originally Posted by 1991sleeper
Take a crescent wrench n flare the end out so u can get it started
Old Apr 13, 2014 | 06:53 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
Re: Advice for a slip-fit cat that won't slip on?
If your local muffler shop has an old pipe expanders that may work to open up the inlet on the cat.
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Rent one of these for free from a local parts store?
(Don't have to expand it as much as bring it back to round.)
http://www.autozone.com/autozone/acc...ander/_/N-25fc
Old Apr 16, 2014 | 03:07 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Thanks all for the ideas!
I took it to the local muffler shop and they did it for free. Got it on last night after fighting with it a bit. Turns out the new one is about half in longer than the old and it played havoc with my fitment! haha
Hotrodboba400
Dec 10, 2019 07:07 PM
billybob6110
Sep 23, 2015 01:30 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
mrdevontay
Sep 2, 2015 08:04 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
