Cat placement
Old May 13, 2014 | 02:05 PM
MrBrooks's Avatar
Car: '92 RS
Engine: 357ci
Transmission: G-Force t-5
Axle/Gears: 4.10 10bolt mini spool
Cat placement
Im about to finish up the 434. It will a set of Dougs LTs on it.
my question is, how far past the collectors do i need to place the cats?
I want to put a flange on the cat and bolt directly to the collector. Will have another flange on outlet to build the y-pipe from. My fear is that if place thsm that close to the collector i will "cook" them.
I may need to just call the mfg and ask..........if i can find someone there that has the answer........lol.
I'm looking to prove that GOOD hp can be made through cats and a muffler..........will be 3" y into 4" out the back with a Hooker MaxFlow.
I intend to get some dyno numbers with cats and again with test pipes.
I'll bet the numbers will be close.............very close to same same.......we will see.
LT1Formula
Oct 8, 2015 08:34 PM
jaridjohn
Oct 5, 2015 07:01 AM
