Why does my car smell bad??
Old Jul 7, 2014 | 09:13 PM
coltonfox34's Avatar
Car: 1986 Z28 Camaro
Every time I start my car, I see white smoke come out of my tailpipes and i mean a lot of smoke but it's only when i start it. While I'm driving it, i smell carbon monoxide the whole time. What could be the problem?
Old Jul 8, 2014 | 04:40 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Re: Why does my car smell bad??
White smoke indicates coolant/water. Check for any coolant leaks, do a pressure test. Carbon monoxide is odorless, you cant smell it. You could be smelling gas, but that typically is black smoke. If you're smelling exhaust while you're driving, check for exhaust leaks around the engine, like the manifold gasket or y-pipe.
Old Jul 8, 2014 | 10:01 PM
NowhereFast's Avatar
Car: 87 Trans Am, 99 WS6, 16 Mustang GT
Engine: LB9, LS1
Transmission: 700R4, T56
Axle/Gears: 3.42 Posi, 4.10 Posi
The white (slightly blue) smoke is most likely valve seals. Heavy exhaust smell could be from a leak, or a gutted out or missing cat.
Old Jul 17, 2014 | 10:06 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Put a cat on it and the smell will go away
bryan623
Mar 22, 2021 06:43 PM
maroe624
Apr 16, 2017 08:29 AM
86IROC112
Apr 9, 2016 10:20 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
