Cat Converter Rattling Noise
Old Aug 9, 2014 | 12:23 PM
19875speed's Avatar
Car: 1989 Formula Firebird
Transmission: 5-speed
Axle/Gears: 3:45
I have the factory dual cats on and the pieces inside the are breaking apart and making a rattling sound. Undecided if I'm going to replace them or just have them emptied out. But in the meantime is it safe to drive the car with this problem or should I park it until I get it fixed? Thanks
Old Aug 9, 2014 | 02:17 PM
Canucksfan1's Avatar
Car: 1987 z28 I-roc
Engine: Carbed 350
Transmission: 700r-4
Axle/Gears: Stock
Re: Cat Converter Rattling Noise
Well I don't think your going to do any more harm to the cats they sound like they are already shot.
The problem you might run into is these pieces in the cats restricting airflow so much that the pressure will build in the exhaust causing your car to run poorly, and if bad enough it may get to the point where it is no longer drivable.
Old Aug 10, 2014 | 01:58 PM
twowwwerf's Avatar
Shouldn't do any harm, just won't be as eco friendly as it used to.
Hotrodboba400
Dec 10, 2019 07:07 PM
GouldyGTR
Sep 7, 2015 09:05 PM
Stryker412
Sep 7, 2015 09:11 AM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
Ian Irvine
Sep 4, 2015 08:08 AM
