should I remove air tubes found leak
Old Aug 23, 2014 | 07:36 PM
tylerf's Avatar
I live in a state where they dont do emissions, I dont have a cat already and i just found a leak where the air tube that connects to the 2nd spark plug on the header, the nut that screws into the header is all rotted out and leaks air which makes a really annoy humming sound, does it do any harm to remove the air tube and plug the holes
if so how would I go about doing this, it is a all stock 88 gta 305, would I gain anything from this
Old Aug 23, 2014 | 08:06 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: should I remove air tubes found leak
Save money and replace with quality headers and a Y pipe. Check the stickies about headers for selections.
Old Aug 23, 2014 | 08:16 PM
tylerf's Avatar
I would love to save for headers but right now is not a good time, how much would it cost for plugs and what size would I need, I details on how todo it would be very nice
Old Aug 24, 2014 | 09:06 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
I forget the actual size, but you can get the plugs from a hardware store. but make sure you buy straight ones. as the tapered ones tend to not stay tight. and you can just cut the air injection tubes off at the manifolds and use a 6 point socket to remove them. be sure to use BP blaster though.
Old Aug 24, 2014 | 08:54 PM
TallTim's Avatar
Car: 1989 Formula T-Top
Engine: 350 TPI, twin turbo
You may be forced to dive in deeper than you want. I tried the plugging of the stock manifolds. Got to the last nut (rear pax side) and the nut broke off in the manifold.
Tried to thread it out but the tap broke in there.
So now I've got hookers on...
Good luck, go slow and I second the PB!
TheExaminer
Aug 26, 2015 04:59 PM
bjpotter
Aug 12, 2015 06:06 PM
3rdgenparts
Aug 8, 2015 07:09 PM
drathaar907
Aug 6, 2015 04:20 PM
antares57
Aug 6, 2015 07:47 AM
