Exhaust Upgrade ? - Hooker Headers and AIR
Car: 1988 Firebird Formula
Axle/Gears: 3.42 Posi
Hello All,
I am swapping in a 350 TPI and am going to get some Hooker Headers without the AIR pipes. I have read plenty on here about the 2055 Hookers, but can anybody chime in with their experiences with the more budget friendly 2460s and their Y pipe friend at Summit?
http://www.summitracing.com/parts/ho...model/firebird
http://www.summitracing.com/parts/hok-16767hkr
Also, obviously I am going to removing the AIR system...
My question is, if I remove the AIR system can I just block off the AIR tube that is currently going into my catalytic converter? If I weld the tube shut can I keep using that cat without any problems?
Thanks!
Thanks!
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: Exhaust Upgrade ? - Hooker Headers and AIR
They are a slightly different design. The 2460s have thicker walls which may reduce flow. The Y pipe for the 2460 kinda sucks and needs to be modified at the merger although you can use the dougs version.
https://www.thirdgen.org/forums/exha...l-exhaust.html
https://www.thirdgen.org/forums/exha...ke-3-inch.html
http://www.summitracing.com/parts/do...d4vRoCESzw_wcB
1992 Trans Am
May 10, 2023 07:19 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
