Need help identifying this part
Old Aug 19, 2015 | 06:24 PM
Nj1987's Avatar
So can't figure out what this line is or where I can get a new one. It goes into exhaust manifold on the passenger side. Any help would be appreciated or if there's a way to fix it. Couldn't get a great pic but basically the line had a hole burnt through it about 1/2 an inch long. Didn't go all the way through the other side though. Almost looks similar to a brake line but obviously it's not.
Old Aug 19, 2015 | 07:35 PM
Re: Need help identifying this part
What did it hook up to?
All we can tell from the pics is, it's a piece of red rubber hose with threads hanging out.
Looks like also, the AIR injection tube is rusted through at the left-hand-most cyl in the first pic, right at its 90° bend...
Old Aug 19, 2015 | 07:46 PM
Nj1987's Avatar
The line with the hose isn't what I'm referring to its the other one the steel line or whatever it is
Old Aug 19, 2015 | 07:54 PM
Oh... I guess I guessed wrong what you were asking about.
Well then, that piece of red rubber hose, whatever it goes to, has a hole in it, in addition to the AIR injection manifold being rusted through.
Old Aug 19, 2015 | 07:58 PM
Nj1987's Avatar
The red rubber hose is a temp fix on something till tomorrow when I can get a new part, the air injection tube I suppose is the only thing I guess I needed help with. How hard are they to replace
Old Aug 19, 2015 | 08:26 PM
Not too bad; not much worse than anything else.
Rotate all hardware counterclockwise. Allow gravity to take over. Installation is the reverse of removal.
In the case of those specific things, getting the flare nuts out of the manifolds is the only thing remotely close to "hard".
Get a new AIR check valve instead of trying to get that old one off... looks like it's in about the same overall condition as the tubing manifold.
LT1Formula
20
Nov 14, 2015 12:02 AM
Linson
Aug 21, 2015 02:12 PM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
