my left side headers are smoking
Old Nov 10, 2015 | 04:22 PM
angelr's Avatar
Car: 1982 camaro berlinetta
Engine: 5.7 350 swap
Transmission: th350 swap
Axle/Gears: 26 spline 7.5 ring gear
My left side header is smoking bad when I turn the car for a while even if I drive it for like 20 minutes it still smokes I don't know what is wrong with my car can someone give me advice on how to fix it or to look for what's causing it to smoke please and thank you
Old Nov 10, 2015 | 05:29 PM
ChevCamZ28's Avatar
Car: 1991 Z28
Engine: 5.7L 350
Re: my left side headers are smoking
Have you done any work where oil dripped on the headers? Mine did that for a while when I adjusted the valves on mine until the oil burnt off. If not, check to see if the valve covers are leaking oil onto the headers if so maybe replace the gaskets.
Old Nov 10, 2015 | 05:44 PM
angelr's Avatar
Well my engine is new its a swap so yes I'm sure I grabbed the headers with my hands filthy with oil and my gasket was leaking a bit because the rubber gasket it had melted so I just replaced it with a new cork gasket and ran the car for 30 mins and it stopped smoking
hotrodjames
Dec 15, 2015 01:11 PM
xbmx89
South Central Region
Dec 1, 2015 08:17 AM
customblackbird
18
Nov 16, 2015 03:02 PM
Mirror Image
Nov 12, 2015 06:09 PM
cowboysfan20
Nov 5, 2015 12:46 AM
