passin' smog questions. ..
Old Dec 21, 2001 | 07:25 PM
OUTATIME GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
Haven't smogged my GTA since I bought it. It's bone stock, but I know the valve seals need to be replaced (some white smoke upon startup only).
Will that affect my passing smog? Any tips on what I should upgrade etc, to ensure passing? Thanks.
Old Dec 22, 2001 | 06:40 AM
Boosted GTA's Avatar
When I still had my 87, I had the same problem with smoking as the car started up, but I passed emissions testing just fine. Then South Florida got rid of the testing
Old Dec 23, 2001 | 03:17 PM
myrocz's Avatar
I have the same problem with smoking when the car is first started (loose rings). I passed smog last year at a test only station with no problems. Just make sure its good and warmed up before you test.
Old Dec 23, 2001 | 06:44 PM
Z28DJP1987's Avatar
The valve seal white smoke will not prevent you from passing the smog check. Just make sure you are at operating temperature.
jaridjohn
Oct 5, 2015 07:01 AM
wstephan96
Sep 25, 2015 04:28 PM
