ZZ4 header recommendations
Car: 1991 Trans Am GTA
Engine: 355
Transmission: 4L60
Axle/Gears: 4th gen 10 bolt 3.42 posi
Just swapping to ported ZZ4 heads and cam. My hedman's will be blocking a lot of the port, so need another compatible set. What's recommended?
Car: 1982 Z-28
Engine: 383
Transmission: Turbo 350
Axle/Gears: Det. Posi, Superior Axles, 3:73 G
Re: ZZ4 header recommendations
Dons is a great and popular choice with the 1 3/4 primary. Or if L/T Hooker 2210 or Dougs 3321.
Car: 1991 Trans Am GTA Drag Radial Car
Engine: F-2 Procharged 18* 434 sbc on Alky
Transmission: Powerglide,Neal Chance Converter
Axle/Gears: Moser 9" Ford 3.50's,35 spline axle
Dyno Don's 1 3/4 headers and y-pipe. His headers are made to work with ANY head ports, along with the raised ports. They will work with both Angle and Straight plug heads too. They are, by far, the best fitting and easiest to install shorty header available for our third gens. Just make sure you use the recommended ARP 5/16" headed header bolts, and the recommended Earls gaskets. They are ball collector design, so they don't use collector gaskets.
Brian
Brian
Engine: 355
Transmission: 4L60
BUMP.
I'm in too big of a hurry and too small of a budget for Don's. I need something a tad cheaper that comes with a Y pipe, will bolt up to these heads, has no emissions, and I can get here in a decent amount of time. Shorties are preferred.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I have not personally tried the OBX shorty header, but the OBX longtube is a really nice header for the money.
http://www.ebay.com/itm/OBX-Exhaust-...mtr&rmvSB=true
Now what is interesting is these headers say they are 1 5/8" primary. The long tubes are advertised as 1 5/8" as well, but they all measure 1 3/4". So these could very well be the same deal. I find evidence in the pictures - the flanges look the same, the primary tubes look about the same as on the long tubes.
If someone were to try them they could be a decent replacement for SLP headers, which are no longer made.
If given the option, i'd go with stainless headers. Even if they discolor over time, it's better than the ceramic coating falling off and they won't rot from the inside out like mild steel headers.
-- Joe
-- Joe
C409
Mar 24, 2016 07:53 PM
85@IRocZ
Mar 7, 2016 12:28 PM
