Mangaflow 16829 Question
Old Jan 4, 2017 | 05:05 PM
Grizzenaznopper's Avatar
Car: 1992 25th Anniversary Camaro RS
Engine: 358
Transmission: 5 speed manual
Axle/Gears: 4.10
I was wondering if the magnaflow #12267 muffler is the same muffler that is in the #16829 cat back kit just with a satin finish instead of a polished finish.
Old Jan 5, 2017 | 05:57 AM
TORN's Avatar
Car: 88 IROC-Z
Engine: 6.9L TPI(FIRST) 421ci
Axle/Gears: Ford 9" Eaton truetrac 3.50
Re: Mangaflow 16829 Question
If no one chimes in today I will measure mine tonight It looks to be very close.
Old Jan 5, 2017 | 08:59 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Looks to be the same.
Per summit racing
Q: Can anyone provide the dimensions of the muffler in this kit. I am just looking for a rough length width and height. If not the part number for the muffler used would also work.
Asked by COREY on November 10, 2016
A:
Thank you for your question. MagnaFlow 16829 has a muffler that is
5 in. x 8 in. x 18 in.
https://www.summitracing.com/parts/mpe-12267
#12267
Case Exterior Length (in.): 18.000 in.
Overall Length (in): 24.000 in.
Thickness (in): 5.000 in.
Width (in): 8.000 in.
Old Jan 5, 2017 | 09:56 AM
Buddy's Avatar
Car: '87 FIREGOOSE!!!!
Give Magnaflow a call, the gang there are always happy to help out.
Old Jan 5, 2017 | 01:57 PM
Engine: 358
Axle/Gears: 4.10
Thank you all for your help
