So i got one header in
Old Apr 2, 2017 | 12:20 PM
SketchyZed's Avatar
Car: 1991 camaro z28
Engine: 5.7
I have hedman 68460 i have one header on as of right now but im wondering if i need to massage this tube for clearance
Old Apr 2, 2017 | 04:55 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
Re: So i got one header in
are those long tubes? i thought that # was shorties i have the 68461 that is ceramic coated they fit great except i had to grind the driver side collector mount a bit
Old Apr 2, 2017 | 09:23 PM
SketchyZed's Avatar
Engine: 5.7
Yes they are long tubes
Old Apr 3, 2017 | 05:35 AM
83 Crossfire TA's Avatar
It looks like it's touching or close to it in the second picture. If that's the case it will rattle. If it's in a place where you can get to it then I would consider leaving it and seeing if it clearances itself after revving it a few times/a few hard runs and if it doesn't then dent it. If it isn't then mark it, pull it and dent it, better now then having to disassemble everything later.
Old Apr 3, 2017 | 10:33 AM
SketchyZed's Avatar
Engine: 5.7
okay thank you
