Exhaust, True Dual, Shops in California
Hey everyone. I have a 86 Camaro. stock ls3,t56. running hooker 2.5in true dual set up. their long tubes as well plan on doing some work to the engine looking to put down around 700whp. so with that being said I'm sure this 2.5 in is to small an ill need bigger. anyone running a true dual 3in setup? will that fit? Brand? if not anyone know of a shop in northern California that can do some custom work for me? thank in advance.
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: Exhaust, True Dual, Shops in California
No one makes a true dual 3" you will have to make it your self. You might also want to consider a panhard bar relocation kit to give you more clearance over the axle
http://umiperformance.com/catalog/in...roducts_id=289
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
NorCal muffler in Manteca did my y-pipe and adjusted the catback and it was very well done. His work isn't cheap but it's damn good. I have pics of his work posted in the "y-pipe question" thread.
