Exhaust Flange Studs
Old Jul 25, 2017 | 05:32 PM
Shane Jackson's Avatar
Anyone have a part number for the passenger side exhaust flange stud? Cant seem to find it. They are longer than the drivers side because they go through that thick spacer. I plan on getting the Magnaflow y pipe also, does that spacer go back on or is the new y pipe long enough to get rid of the spacer?
Old Jul 25, 2017 | 06:32 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Exhaust Flange Studs
Dorman 03101 for the long 77mm and 03102 for the short 65mm.
Old Jul 26, 2017 | 01:10 AM
NoEmissions84TA's Avatar
I buy long stainless steel bolts, cut off the head, and then make new threads on the cut off end, turning it into a stud that doesn't rust.
Old Jul 26, 2017 | 01:41 AM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
I just drill them out and use bolts.
