Running spark plug wire without boot?
Old Aug 7, 2017 | 06:50 PM
Wickydooda's Avatar
So I have these Doug's headers and while the metal seems to be high quality, the fitment is absolute crap. Spark plug #7 rubs against the headers with boot installed. Would it be a bad idea to run just #7 without a boot?
Old Aug 7, 2017 | 08:33 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
Re: Running spark plug wire without boot?
yes it would be a very bad idea. it would arc out on the header and not fire the cylinder..
Old Aug 7, 2017 | 09:34 PM
NoEmissions84TA's Avatar
The Accel "shorty" header plugs are the shortest I have found.
But in your case, I don't think those will even help.
Old Aug 7, 2017 | 09:41 PM
Jorlain's Avatar
Car: '84 Trans Am
Engine: 357 SBC
Axle/Gears: 10 Bolt 3.73, Torsen Diff
I'm running NGK V-Power spark plugs and I have enough clearance to not touch, even with them being wrapped on the Doug's longtubes. Maybe buy one and see how that goes for you?
Old Aug 7, 2017 | 10:42 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
That's #7? And straight plug heads?
Yeah, shorty plugs should be tried, or the primary tube modified.
Old Aug 7, 2017 | 11:57 PM
Wickydooda's Avatar
Those are actually the same plugs I am running, and they are way too long for my application.
Upon doing some research I discovered that shorty plugs exist. I ordered a set of the shortest shorty plugs from Summit so we'll see tomorrow if that works. Also I ordered some plug wraps for further insulation, hoping that doesn't just amplify the clearance issue I am having.
Also, prior to reading the comment about arcing, I tried out running the plug without a boot and sure enough it was just arcing off the wrapped header bad enough to not even fire the cylinder... hopefully it didn't hurt my brand new engine
Old Aug 8, 2017 | 08:18 AM
Jorlain's Avatar
Car: '84 Trans Am
Engine: 357 SBC
I'm sorry to hear that, man. What heads are you running? I'm running aftermarket heads, but AFAIK the plug placement should be the same as 906 Vortec heads.
Old Aug 8, 2017 | 11:33 AM
Wickydooda's Avatar
383 Stroker from a LT block, EDL-2022 (Summit PN#) heads. I believe they are called "Edelbrock E-Street heads. The headers are the Doug's PN# D3321-R.
Old Aug 8, 2017 | 11:45 AM
Abubaca's Avatar
I had a similar situation with my RHS heads and SLP headers. #8 cylinder. Burned through the first boot which actually touched the header. Put on another boot, but trimmed it down so it wouldn't physically touch. The boot stayed together, but still burned, and started arcing. Now I'm running a DEI wire protector, and no arcing. The wire sleave/protector is DEFINITELY touching the header, but between that and a new, trimmed boot, I have no arcing.
...I'm also running Remflex header gaskets, which are about a 16th of an inch thicker once compressed. That's a lot of real estate in these situations.
Old Aug 8, 2017 | 02:16 PM
Wickydooda's Avatar
Wow i didnt even think about that
Old Aug 9, 2017 | 08:16 PM
MSgt Luttrell's Avatar
Car: 1986 IROC Z28
Engine: Carburated small block 454
Transmission: Level 3 Raptor 700R4 2600 stall
Axle/Gears: Strange S60 3:73 S Trac Posi
I'm also running Doug's long tube headers, with aftermarket aluminum straight plug heads and what I did was run the thick aluminum header gaskets and slightly dented the #7's primary tube right where the boot sits; all this gave me a good .250" of space between the boot and header, running Champion 792 racing spark plugs.
Old Aug 9, 2017 | 08:52 PM
TOM305T/A's Avatar
Car: 1987 GTA 350 auto
someone out there makes wires with ceramic boots. i seen them in ads.dont know anyone who used them
Old Aug 9, 2017 | 09:46 PM
Jorlain's Avatar
Car: '84 Trans Am
Engine: 357 SBC
Ingenious. I hadn't seen those before. Might cure problems for a lot of folks.
Old Aug 9, 2017 | 10:28 PM
Wickydooda's Avatar
I've got shorty plugs coming in the mail tomorrow, but normal header gaskets, and I don't feel comfortable denting my expensive headers.
I've also got PN# HMI-8030 spark plug boot insulators. Have yet to use them but from the feel of them they are extremely sturdy and seem like they should last forever.
Old Aug 10, 2017 | 08:18 AM
Jorlain's Avatar
Car: '84 Trans Am
Engine: 357 SBC
It's amazing how much they can get away with charging for heat shielding products these days. Good grief.
Old Aug 10, 2017 | 10:18 AM
Wickydooda's Avatar
Yeah but at the same time if I were trying to save money then I'd go join civicforums.com
Old Aug 10, 2017 | 06:55 PM
You could always buy a header flange to use as a spacer and use gaskets on both sides.
Old Aug 10, 2017 | 07:10 PM
TOM305T/A's Avatar
Old Aug 12, 2017 | 01:32 AM
Wickydooda's Avatar
this seems like a very viable option.
running shorty Accel spark plugs has given me enough clearance to put the plug boot on as well as the thick plug boot protector from Summit. The protector touches the header quite firmly but I think they are quality enough to not disintegrate from heat. Also my headers are wrapped so I'm sure they'll be fine. Thanks for the help TGO!
