Header Temps
Old Aug 20, 2017 | 01:40 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Header Temps
Hi Guys,
I'm finally getting back to my 89 Formula 383. I took a laser temp gun and pointed it at each (ceramic coated) header tube and noticed some had a large temperature difference. Obviously, they will never be exactly the same but one showed around 300* while another was closer to 500*. Is this normal? Or does this indicate a fuel or valve issue?
Any input would be appreciated.
Thank you!
Old Aug 20, 2017 | 01:50 PM
Re: Header Temps
Could be any of that.
Could also be just a difference in coating thickness, or in air flow over them.
Might want to check at various places along their length.
300° seems kinda low though.
Old Aug 20, 2017 | 01:53 PM
Re: Header Temps
Thanks sofakingdom! Much appreciated.
Old Aug 21, 2017 | 07:59 PM
NoEmissions84TA's Avatar
Re: Header Temps
I have a home-made engine test stand. On it is my rebuilt 334 SBC. I did the same test as you and got the same result. My point being is that you probably DO NOT have any problem at all. Don't create one out of nothing.
