1995 k1500 y pipe
Old Nov 9, 2017 | 09:19 AM
dannyidp's Avatar
1995 k1500 y pipe
Hey guys I have the 305 tbi and planning on stepping up to the 350 tbi later. Im not looking to burn rubber but pulling towing torque. I want to know if the factory y pipe is robbing power? Would I benifit running duals? Thanks
Old Nov 9, 2017 | 02:57 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: 1995 k1500 y pipe
I would probably ask on a Chevy Truck forum
Old Nov 10, 2017 | 09:14 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
I can answer that.
The Y-pipe isn't going to get you anything. Those truck motors are slugs, good for torque and nothing else. (I have a 95 k2500).
Old Nov 10, 2017 | 10:30 PM
dannyidp's Avatar
Thanks red leader 289 I thought that was what was already on there from the factory was a y pipe. It has a pipe coming off both sides with the drivers side going into the other then into the cat. Isn't that considered a y pipe? I was wanting to know if duals would help or is it worth it.
Old Nov 12, 2017 | 05:03 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Axle/Gears: G80 3.23
Itll help a little if you have headers and high flow cats and mufflers. But apparently the camshaft is the bottleneck
More info here:
http://www.gmt400.com/
Old Nov 13, 2017 | 07:29 AM
Car: 1983 Z28
Sorry, yeah what's on there now is a Y-pipe. True duals will get you more sound but that's about it.
