H and X pipes
Old Oct 11, 2018 | 04:02 AM
mjoekingz28's Avatar
Car: 2006 Chevrolet Cobalt
Engine: 2.2 DOHC Ecotec
Transmission: 4spd auto
H and X pipes
What is the point (or idea) behind connecting the left bank and right bank together on a true dual setup.
I have an LQ4 with true duals and no such crossover pipe or 'connector'.
Do they typically produce a different sound or help match both banks of cylinders for a V8
Old Oct 11, 2018 | 06:37 AM
soloc4's Avatar
Car: 84 Z28, 92 C4 suspension F&R, ABS
Engine: 408 LS2, CNC LS3 heads, Comp Cam
Transmission: Magnum F, RTX clutch, Tick shifter
Axle/Gears: DANA 44, Tru Trac, 3:73 gears
Re: H and X pipes
The "balance" pipe does make the exhaust sound more uniform and helps scavenging slightly. The H pipe has a deeper, raspier sound were the X pipe is smoother with a little higher pitch sound.
Old Oct 11, 2018 | 07:47 AM
kaos420's Avatar
Car: 88 gta
Engine: 5.8
Axle/Gears: 3.73 POSI
Re: H and X pipes
engine master did a really good video on which one to use
Old Oct 11, 2018 | 09:06 AM
berlin305's Avatar
Car: 1987 Iroc Z 1990 RS 1991 RS
Engine: 454 soon 496
Transmission: Soon T56
Axle/Gears: 308 Posi
Re: H and X pipes
Yea about to say Engine Masters did a good job testing them on the dyno.
Old Oct 11, 2018 | 09:42 AM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: H and X pipes
They equalize the pressure between cylinder banks, which improves throttle response and low-end torque. They make the exhaust SLIGHTLY quieter at idle. The X definitely sounds different from the H, but neither has a power advantage over the other, it's just at a different RPM between the two. It's about 2 to 4 horsepower...
Old Oct 12, 2018 | 08:14 AM
GOTCHEVY's Avatar
Car: 97 Z28
Engine: 396 LT1 518whp All Motor
Transmission: 6spd
Axle/Gears: 4.10 LSD
Re: H and X pipes
Old Oct 12, 2018 | 02:14 PM
T.L.'s Avatar
Re: H and X pipes
All spot-on, except for the part about the X making more HP than the H.
BOTH produce an additional 2 to 4 HP over nothing at all. The X produces the increase at a higher RPM, and the H at a lower RPM...
Slow89Iroc-Z
May 12, 2004 06:01 PM
Slush92RS
Jan 17, 2001 08:21 PM
