Dan Lemons Headers..
Old Nov 4, 2018 | 02:34 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
So some of you might know who Dan Lemon Is..some may not. he is the Guy who will make you a set of headers to order..1 set at a time. some times running 6 to 8 weeks out.. in the tube size that works best for your eng set up..(mine is 615cid turning just under 6800rpm)
http://www.lemonsheaders.com/contact.htm
anyway. I put in my order and gave up the cash $2150 shipped for the set of headers I wanted 2 1/8in primary tube down to a 3 1/2in collector. Ceramic coated inside and out. this is for my BBC. some of you know I made the jump/switch from SBC to BBC. and nothing fits the same..anyway he sent me some pics of the fitment im going to do to install the headers..i wanted to post the pics (not my car) but of the fitment..
this set of headers is meant for front drag when setup. as some of the tubes go through the lower wall. behind the front wheels..in the wheel well. not a prob if your into drag racing setups..(I AM)..
NOTE: Ill make the holes as clean and neat as I can...possibly installing the tubes from the eng bay out..instead of wheel well in..(dan told me he has not tried that..and cuts the holes to fit the flanges..and tubes then fit the collector. and bolt up..(we will see) as I don't want to chop up the car....lol but this eng need to breath!..
My set of Header also are getting 3 bolt flanges on them. to bolt up to cut outs.. then go out the back of the car..(the plan anyway)
this ZL1 Tribute needs to Breathe!
damiano1
Apr 8, 2012 12:13 PM
radialtireking
Dec 9, 2006 03:49 PM
louich
Aftermarket Vendor Review
Feb 15, 2004 11:14 PM
