corvette headers
Old Jan 9, 2002 | 02:57 AM
Keith Taylor's Avatar
corvette headers
has anyone fitted a set of standard vette headers to an 88 iroc 350tpi?
Is there much of an increase in power over the stock cast items
My car has been converted to right hand drive so all the off the shelf sets discussed on this site aren't necessarily going to fit.
88 vette headers look as though they should clear everything and I was thinking of going twin cat as well. Is it worth the effort and will I notice a difference with the above set-up? I cant get much help "down-under"
Old Jan 12, 2002 | 01:00 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I dont think they'll fit, but I dont know for sure...
Old Jan 12, 2002 | 02:21 AM
Jza's Avatar
Jza
The Corvette headers (the actual stock headers like on the 86, not manifolds like earlier) exit in the center directly under the center exhaust ports, and low on the block. They would run right into the crossmember.
You might have better luck with aftermarket Camaro headers, even if you have to mix and match a set from different brands.
Old Jan 12, 2002 | 04:41 AM
thanks for the, info looks like a set of tailor mades is the go
no after market available down here
Drone358
Dec 10, 2015 08:16 PM
85 Jimmy
Sep 30, 2015 07:56 AM
Chad Speier
Sep 24, 2015 12:32 PM
hdis2002
Sep 8, 2015 02:52 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
