17478 hedman... what cat?
Old Nov 19, 2019 | 08:26 PM
1badbowtie's Avatar
Car: 88 Trans Am
Engine: 305 tpi
What cat should I go with using Hedman 17478 y pipe? Seems most tpi cats I’ve seen are 3” but the y pipe is 2.5”?
Old Nov 24, 2019 | 11:02 AM
Re: 17478 hedman... what cat?
DO NOT spend A SINGLE DIME on any 2½" exhaust parts, past the Y-pipe.
If the Y-pipe is 2½", throw it in the trash, and get a 3" one. No doubt Hedman offers one. Then get a 3" cat and a 3" cat-back.
Otherwise you are retaining, or INSTALLING, the LG4/L03 BOTTLENECK, a guaranteed restriction that will invalidate ALL other efforts to upgrade the engine.
Old Nov 24, 2019 | 12:09 PM
Drew's Avatar
Most if not all of the HO exhausts are 2.75". What causes confusion is that the stock intermediate pipe necks down to 2.5" where it enters the muffler. So, some of the aftermarket stuff rounds up to 3", some rounds down to 2.5". The low output exhausts, and 6cyl exhausts are all 2.25". So for some aftermarket exhaust parts, they average everything out to 2.5" and use one part fits all.
So, measure what you have first to be sure. Usually the ball/flare flanges are flexible enough to go up or down .25-.50". There's usually .25" just going from inside diameter to outside diameter. Most auto parts stores will have bushings, reducers, and adapters to go up or down in size. In fact, it looks like the Hedman Y-pipes come with a transition to go up/down a size.
_87TA_
May 6, 2010 02:09 AM
91 camaro rs
Feb 19, 2007 05:08 PM
safemode
Jul 24, 2006 09:23 PM
squirrelybird
May 15, 2004 11:08 PM
AFRO IROC Z
Aug 21, 2001 11:25 AM
