Do I need lock washers or OEM lock plates for factory exhaust manifolds?
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
I removed, cleaned and replaced the stock exhaustmanifolds and some of the old metal tab nut lockers broke or are missing. Not sure I need them. All factory going back on.
Engine: LB9 305
Transmission: AT
Re: Do I need lock washers or OEM lock plates for factory exhaust manifolds?
Lock washers will loose tension due to the heat. I'd go with lock plates.
Put a little anti-seize on the threads if you ever want those bolts to come out in one piece again.
Car: One owner '88 IROC 50k
Engine: L98 with bolt ons.
Axle/Gears: 3:42 again
You can make your own lock plates with some sheet metal and tin snips
Nah, GM just put them on there for sport. <heavy sarcasm> GM used them because they didn't want warranty claims and service calls for leaky exhausts. If you want them to be leak free and can't afford for the bolts to work loose, a similar locking solution is a good idea. I seem to remember seeing the factory style lock tabs in the Help! section, but I haven't looked in years. Plenty of older GM applications have reproductions available, one of them might fit. Or get super trick and safety wire all your hardware for that aircraft look. Or just let er buck, because you can always torque the bolts again, or deal with the problem when it presents itself.
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
I have had my stock L69 manifolds installed now for a few months. The mechanic did not reuse or add any locking tabs and did use the high temp anti seize on the bolts. After a few heat cycles I retightened the bolts, on a cold engine, and a couple were lose. I have had none loosen up since and I just checked them a couple weeks ago.
VincentZ28
Southern California Area
Nov 5, 2008 01:26 AM
stangStomper83
Jun 22, 2006 07:38 AM
