Hooker 2055's with a T56
Old Apr 17, 2020 | 10:55 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Will the Y-pipe clear okay? I have line on a unused set for a good price, would like the seller to send them to JetHot for coating first, JH will send to me. Thing is, if I have to slice the Y-pipe up to fit...hence my question.
Old Apr 18, 2020 | 02:10 AM
Drew's Avatar
Re: Hooker 2055's with a T56
Pretty sure the Hooker Y-pipes follow the stock routing, they never come near the hydraulic clutch slave that causes some exhausts not to fit the manual trans cars.
Old Apr 18, 2020 | 09:53 AM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
They worked just fine on my car.
The Y-pipe crosses over just behind the oil pan so it fits without an issue. The T56 is physically smaller anyways so if anything there is even more room to work with.
Old Apr 18, 2020 | 10:25 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Thanks Gents, deal is too good to pass up, but nice to know I can save a few bucks on shipping.
Thanks again!
Old Apr 18, 2020 | 10:49 PM
Do yourself a favor, use some grease or something to mark out how the y-pipe sits on the collector's ball flange after its all mounted up. Mark it off, then port it.
The 2055 collectors use a ball flange setup for fitment, but that also cause some small restriction. So once you know how they fit on your car you can open them up a little for a bit more flow.
Troy Metcalf
Apr 17, 2017 12:20 PM
COTY'S IROC-Z
Oct 5, 2010 11:58 PM
zacharyhorn
Aug 2, 2006 12:10 PM
dhirocz
Jan 10, 2004 10:36 PM
