CHECK ENGINE LIGHT - CODE 44
Old Mar 19, 2021 | 12:53 PM
1989_RS_8DZROC's Avatar
Transmission: 700 R4
For a 1989 305 engine with TBI, does anyone have experience with CHECK ENGINE LIGHT - Code 44? I grounded the upper two right terminals, to get the code. Flashing sequence indicated code 44. After some reading/research, others have suggested replacing all of the following gaskets and emissions parts.
Intake Manifold Gaskets (to engine)
Throttle Body Injection (to Intake Manifold) Gasket
Oxygen Sensor
EGR Valve
Idle Air Control Valve
If this was the case for you, were these parts replacements successful in clearing the code and having engine run better?
Thanks for any help!
Old Apr 6, 2021 | 02:33 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Re: CHECK ENGINE LIGHT - CODE 44
id start with the 02.
The EGR would probably make it run bad if it was stuck open etc..
19WS6T/A91
Dec 26, 2002 07:42 AM
91B2L
Mar 28, 2002 08:36 PM
