Why does my check engine light come on intermintenly with a code 36
Old Mar 24, 2002 | 03:43 PM
86Tra/maro's Avatar
From: Newark,NJ The state where racing on I 78 rules.
My question is whats up with the check engine light coming on from time to time when I start the car?The code is a 36 WTF! Sometimes it stays off for weeks at a time. I changed my EGR valve when I installed the motor.
njdaewoo
Old Mar 25, 2002 | 10:09 PM
Guest
Guest
Posts: n/a
A weak battery will sometimes trigger a code 36 to be set erroneously. Might want to check the cranking voltage when it sets the code and when it doesnt and see if there isnt a trend to it.
Old Mar 25, 2002 | 11:20 PM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
Transmission: Goebel 700R4
Code 36 can be a problem at your MAF burnoff relay. It is on drivers side firewall in the engine compartment. Mine gave a code 36 intermittently due to a bad connection at the plug in to the relay. If it is not tight, it can momentarily lose contact and throw that code. We used a pull tie to hold mine together tight. Read my ordeal here on my code problems including 36. https://www.thirdgen.org/techbb2/sho...threadid=94924
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
