Header collector woes
Old Jun 11, 2022 | 10:10 AM
2names's Avatar
Car: 88' Iroc convertible
Transmission: 5spd
I am new to installing headers and have attached a set of Headman shorties to my 305. Thought I had the collector bolts tightened up enough on the driver side but when I checked on it the other day found that I lost one nut, the one on the inside closest to the motor.
The position of this bolt is nearly impossible to get a tool on it. Can't get a socket on the top as it's too thick to fit between the nut and the pipe from the top and from the bottom you can barely get your hand in there.
Looking for any tips on getting that tightened up without starring at it for hours and swearing!
Old Jun 11, 2022 | 12:09 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Re: Header collector woes
Dent the tube until you can fit what you need on there. There exist specialty access tools for these scenarios as well.
Old Jun 12, 2022 | 11:32 AM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
^^^^This.
"Bolt-on" aftermarket stuff rarely does without some modification. As above, 'clearance' the area so you can get a socket on the nut.
Old Jun 16, 2022 | 09:50 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Yup, unfortunately header installation typically includes the use of a hammer
I've found ratcheting wrenches are also helpful in these situations.
When you get them tightened down, drive it a few times to get a solid warm-up/cool-down cycle, then check them again.
JoeMonte
Jul 27, 2016 02:41 PM
jayhawk
Sep 16, 2015 12:22 PM
Evader15
Aug 14, 2009 01:20 PM
Demon355
Sep 1, 2002 03:46 PM
