problem with headers
Old Feb 1, 2002 | 08:48 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
i put the edelbrock tes headers on my 305 tbi engine and on the passenger side there is a braket thatgoes from the i think 3rd header bolt to the compresser. it doesn't go on with the headers. will this be ok or no and if not wut shoul i do
Old Feb 2, 2002 | 07:02 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Odd I cant recal there being a problem with brackets. Usually when you order headders there is a list of extensions and aftermarket brackets to make install easyer. Did you have an option list?
You probably could make it work with washers or bolts staked on top of each other to extend the bracket. I would check around for the proper bracket.
SSC
Street Lethal
Apr 30, 2019 12:14 PM
hectre13
Sep 8, 2015 03:38 PM
tricky1
Aug 23, 2015 01:17 PM
theurge
Aug 21, 2015 12:46 PM
sreZ28
Aug 14, 2015 07:48 PM
