keeping smog pump
Old Feb 13, 2002 | 03:11 PM
d_biel's Avatar
keeping smog pump
I am ready to redo the stock exhaust and want to get some headman shortys and a catback system.I have all the air crap on there now,but i want to delete it because we dont have inspections in SC anymore.Can i leave the smog pump on, will it cause any problems, or do i need to do the pulley delete? And for me using headers w/o air fittings and pipe through cat will it mess with the computer any?I know everyone has opinions about which headers to use, i just want a pair that fits without a lot of trouble.
Old Feb 13, 2002 | 07:39 PM
slowV8berlinetta's Avatar
you can leave the disconnected smog pump on. I did when i put a set of slp headers on a buddies gta, cus the damn pump ate my torx bit. Them sumbitches are on really tight- probably to make it hard to remove em ya think? we're gonna take it off when the motor gets pulled out and we can drill out that bastard bolt- I got all of em but that one. He claims he can hear a hissing from the air pump, but with the hood closed and driving, i can't hear it.
Old Feb 13, 2002 | 11:07 PM
360Iroc's Avatar
torx heads? mine where fifteen mm bolts and they came right off, the longest part was taking off all the piping
Old Feb 14, 2002 | 09:31 PM
usa1racing's Avatar
I deleted the smog pump on mine when I installed headers. I'm 99% positive I used a 97" belt instead of the stock 98". We are talking about a serpentine system right? Mine pump and all associated hardware came off without a problem.
Matt
Old Feb 15, 2002 | 09:08 AM
jrr's Avatar
jrr
Put that smog pump to work
I did the same thing as you with the smog pump but don't throw it out! Hook some copper or conduit piping to the pump, run it to a T-fitting, and then to the back drums. I don't know how much cooler brake drums are from the air but they sure are clean on the inside. Hardly any brake dust at all!
RazorN8
Jan 7, 2022 11:44 AM
italiano67
Dec 11, 2016 09:21 AM
toronto formula
Nov 10, 2015 06:17 AM
krisner89
Carburetors
Sep 20, 2015 08:56 PM
camaro_rs350
Northern California
Aug 18, 2015 12:38 AM
