newbie Cat related Questions
Old Feb 15, 2002 | 07:00 AM
Prem's Avatar
Hi, I am a little confused about the Cat.
1) what is a CatBack muffler?
2) the difference between dual and single CatBack?
3) what are the effects of a bad Cat?
4) If it is not a legal requirement, what are the pros and cons of removing the Cat.
My car cuts out when I am in drive with my foot on the brakes and randomly after it warms up to normal operating temp.
I suspect a clogged Cat.
Any Advise?
Prem.
Old Feb 15, 2002 | 08:13 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Re: newbie Cat related Questions
Any Advise?
Prem.
A "cat-back" system includes all the exhaust equipment (muffler included) AFTER the catalytic converter.
No such animal as dual CATBACK. Just single or dual CATS...single = 1 cat, dual = 2 cats
A bad cat will cause hesitation, backfiring, and sometimes stalling.
Removing the cat can give you more hp, but affects how the car sounds.
Old Feb 15, 2002 | 08:36 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Re: Re: newbie Cat related Questions
Well, if you have dual cats, you need a cat-back for a dual cat system. So, technically, there is such a thing as a dual cat cat-back. It just doesn't have dual pipes back to the muffler.
Old Feb 15, 2002 | 10:00 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Removing the cat will also put more pollutants into the environment. Of course I doubt most people are concerned with this though.
Old Feb 16, 2002 | 05:43 AM
Prem's Avatar
Thanks it is much clearer now. One more Question, If I remove the cat do I have to make any Adjustments to the engine?
Prem.
Old Feb 20, 2002 | 06:07 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
shouldn't as far as I know
there is a good difference in flow but it shouldn't be enough to make you have to tamper with anything else
chazman
Aug 28, 2018 03:25 PM
Out-Cast
Aug 22, 2015 07:49 PM
chazman
Aug 22, 2015 02:01 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
