Cherry Bomb
Old Feb 18, 2002 | 02:16 AM
AlienCatz's Avatar
Cherry Bomb
I want a loud exhaust... . How is a cherry bomb for an idea?,.... Can you possibly just jot or throw all you know about cherry bomb advantage/disadvantage....?
Old Feb 18, 2002 | 12:11 PM
91fbirdgta's Avatar
Car: 91 Firebird GTA
cherry bombs are LOUD, i don't know about performance-wise on an f-body-
aren't they also called glasspacks???? i know those things are loud too-
Old Feb 18, 2002 | 04:37 PM
350turbo411's Avatar
Car: 1983 Z28 Clone
Transmission: TH350
On my monte i cut off the exhaust.....stuck the end of the cherry bomb into the end of my cat ....clamped her home ..............it sounds REAL MEAN....but...i cant even hear my music....if i'm driving down the road ...i turn the music up full blast...then when i come to a stop...i have to turn it down...when i accelerate...i have to turn it up....its cool for a beater but.. not for a third gen..........IMO
pretty much...do what you want............i'd at least go with a cheap jc whitney exhaust before going to a cherry bomb.........
XxRobxX
83 Camaro
'78 305 deep dish pistons
Non-CC 78 Q-jet H hangar DR rods
HEI vacuum advance dist.
Edelbrock open element
Non-EGR Performer manifold
416 heads 1.84"/1.5" valves, 58cc chambers
Edelbrock TES 3"
Catco 3" universal
TH350 with B&M shiftkit
3.73 rear end (one wheel peel)
Rear srping rubbers
Mach sixty road slicks
Old Feb 18, 2002 | 05:47 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Cherry Bomb does make other mufflers besides glasspacks.
I've seen two other mufflers that were Cherry Bombs at Autozone. One was ~$15, and the other ~$30. They are regular oval mufflers like any other.
IIRC, they're called a Turbo ($15) and a Super Turbo. ($30)
AJ
Old Feb 18, 2002 | 10:24 PM
iroc22's Avatar
The oval Cherry Bombs are the turbo style as mentioned above and they sound like a normal turbo muffler, only they burn out faster. Glasspacks are just annoying mufflers; they dont even sound mean just raspy.
Old Feb 19, 2002 | 03:05 AM
Demon Z28's Avatar
Car: 2001 Camaro SS
Engine: Almighty LS1
it also depends on the size of them as well... I mean, a small one, yeah it'll be loud as hell... but the larger 32" ones ... those are great for a really deep subwoofer type rumble ... I enjoy mine currently like that (its right on the Y-pipe so it sounds very interesting)
Not bad until I can get the $$ for a custom dual setup with 2" oval pipe on each side (I've got a manual so I'm getting custom headers done in SS and having them coated) ... no idea what I'm going to use for mufflers though... nor where it'll exit
Old Feb 19, 2002 | 03:48 AM
AlienCatz's Avatar
Well Well Well.... A Lot more responce then I expected.... Yeah I will be going with the longer and thicker version of the "Glass Pack" Cherry Bomb.... I had one on my v6 91 AshBird (Dead Now) and it gave it a low mellow racing rumble.... I liked it.... I was considering puttin it on the 305 v8.... I appreciate all the responce... I will be putting a sound clip as soon as I get one on.... (2-3 days....) Thanks for all your responce.
Old Feb 19, 2002 | 11:27 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
My GTA has a cherry-bomb glass pack in place of the standard muffler. It's not really all that loud, I'm guessing because it's still got the stock POS intermediate pipe to quiet it down. At first I didn't care so much for the sound... I thought the car sounded like a truck, but after I got used to it, I don't mind it so much.
That being said, glass packs are pretty restrictive. Yes, you can see right through it, but the perforations that bottle-neck the inner diameter really kill flow. A muffler like a Dynomax Ultra Flow or Edlebrock RPM, or any other similar style will outflow a cherry bomb.
Old Feb 19, 2002 | 12:51 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
If you want it loud use a 32in turbo tube!!!! If I were to cut the timing gear noise from my truck that has dual 24in glasspacks and compare the sound from my firebird, 1, 32in turbo tube replacing cat 3in od pipe straight back split into two pipes, stock exits, the firebird sounds alot louder and meaner. The firebird has stock exh manifolds and the truck has headders.
SSC
BADNBLK
Convertibles
65
Feb 10, 2016 03:36 PM
Reddeath210
Oct 6, 2015 08:20 AM
87350gtanj
Aug 8, 2015 10:32 AM
ChevyGuy87
May 8, 2001 02:37 PM
GTA88
Jan 12, 2001 10:53 PM
