SLP or Edelbrock
Old Feb 22, 2002 | 06:29 AM
RS91's Avatar
SLP or Edelbrock
I was wondering which one would be best for my 91RS Camaro TBI 305? I wanted SLP because a lot of people here like them. But it seems that it has some clearance issue with the plugs.
What do you guys think..
Old Feb 22, 2002 | 10:32 AM
Js92RS's Avatar
Car: '92 Camaro RS
Engine: 355 TPI
Transmission: Tremec T-56
Axle/Gears: 10 bolt/3.42
I just had the SLP 1 5/8 installed, no plug clearance issues.
Old Feb 22, 2002 | 11:04 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I also have the SLP 1-5/8" tubes.No problems with spark plug clearance at all.Buy the SLP's.
You'll be glad you did.
-Rich-
Old Feb 22, 2002 | 12:37 PM
mcconahay37's Avatar
I had to switch to a slightly shorter plug and 90 spark plug boots when I put on my SLP 1 3/4" headers. They fit fine now. Also check out this thread on why to go SLP:
https://www.thirdgen.org/techbb2/sho...=SLP+Edelbrock
Old Feb 22, 2002 | 03:14 PM
RS91's Avatar
Okay.... If I go for SLP which one? Which one will give me better performance 1 3/4 or 1 5/8?.
Old Feb 22, 2002 | 04:08 PM
1MEAN92RS's Avatar
Car: '92 Rally Sport
Engine: LO3
1 5/8 = more torque 1 3/4 = more hp The 1 5/8 are great for the 305, but If you plan on doing an engine swap later on to get more cubes then go ahead and consider the 1 3/4.
Old Feb 23, 2002 | 06:00 AM
RS91's Avatar
OK... I think I will get the 1 3/4 SLP... PN=30005. Does this Include everythink I need or do I have to buy some other header kit? Also does Summit have them?
Old Feb 23, 2002 | 08:01 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
Just some thoughts on the SLP 1 5/8 headers. I am using them on my ZZ4TPI. Absoluely no problem with my angle plug heads. Easier than the stock L98 heads to change plugs. However, the flanges on the SLP's are so thick, it's about impossible to get a 3/8 12 point wrench or socket on most of the bolts. I had to take my grinder and "clearance" the headers. Other than that, everyone comments on what a quality built header the SLP's are.
Old Feb 25, 2002 | 09:28 AM
Car: 92 Camaro RS
Yeah, it's real tight around the header bolts.I'm using the ARP SS 12 point bolts and had to grind down a 12 point 3/8" box wrench.It's real thin, but so far I haven't broken it.
-Rich-
Old Feb 25, 2002 | 12:14 PM
That's odd you have had problems with clearance for the header bolts. It's tight, but I'm able to fit my 12 point 3/8" wrench around them no problem.
For RS91:
That part number is just the headers and y-pipe. You'll need the install kit also and probably the cat adaptor.
As for where to get them, check out the Spohn SLP group purchase thread at the top. You should be able to save about $100 or so going through him.
Old Feb 25, 2002 | 12:54 PM
prowler's Avatar
need serious help
I have a 92 Z-28 Camaro.With air and Smog control.
This car is a 350 TPI L-98
Problem is somebody took the catalytic converter off.
So what SLP application will I need and this might be a dumb
question. But will I need a catalyitic converter for these headers
to work.
Also the 92 Z-28'S were they single or dual cats?
Thanks people
Old Feb 26, 2002 | 04:09 AM
RS91's Avatar
Does anyone know if I need to order Headers kit if I decide
to buy SLP 30005 for my 91 Camaro?
Thanks...
Old Feb 26, 2002 | 07:04 PM
Originally posted by mcconahay37
For RS91:
Linson
Oct 24, 2025 02:00 PM
no green
Jan 9, 2016 09:22 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
Royal_Z
Sep 30, 2015 08:45 PM
Dragonsys
Sep 25, 2015 03:51 PM
