SLP headers
Old Mar 3, 2002 | 11:15 AM
PimpCamaroRS's Avatar
SLP headers
When i drop my 350 in, in like 2weeks i want to throw some headers onwith it. Well since i am going to be tricking out my 350 ppl have told me to go with 1 3/4 SLP headers. The only thing i wonder is how hard it will be to install them since it goes all the way to the cat and will i need a welder or have any problems when is witch from stock heads to AFR heads? thanx
Old Mar 5, 2002 | 06:06 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Some people have fitting problems that require them to slighty lift the engine or move the steering column in order to get them in.
The headers are shorties, so its the Y-pipe that connects the headers to the pipe, which is a separate piece.
The only problem with your heads might be the spark plug angles. Mine are straight (stock heads) and although I have yet to switch the plugs I can look at and most likely reach all of them with minimal problems.
The only welding you may need to do is at the cat, but you could probably get away with clamps.
Old Mar 5, 2002 | 10:40 AM
well do i need the Y-pipe or can i just get some Slp's that bolt into the old exhaust manifold flange?
Old Mar 5, 2002 | 02:08 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Must use their y-pipe.
Old Mar 5, 2002 | 02:19 PM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
The y-pipe is included when you buy the headers, though.
Old Mar 5, 2002 | 05:45 PM
o...so you think i could just not use the Y-pipe untill i get a welder and just bolt the headers on when i swap my engine? o any other headers with out the Y-pipe..or does the Y-pipe really help?
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
redformula88
Oct 14, 2015 06:08 PM
Nervous2
Oct 8, 2015 10:53 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
alpine247
Sep 16, 2015 05:25 PM
