how can i plug the o2 bung?
Old Mar 7, 2002 | 11:39 AM
350turbo411's Avatar
Car: 1983 Z28 Clone
Transmission: TH350
i have tes and i want to plug the 02 bung....anyone know what size bolt will fit.. or how to plug it..
rob
Old Mar 7, 2002 | 11:56 AM
1982chevycamaroz28's Avatar
use the o2 sensor thats what i got in my manifolds right now. just as a plug and it works untill u find a bolt or sumthing.
Old Mar 9, 2002 | 08:20 PM
mckenzie's Avatar
i would just use an o2 sensor (old sensor that is) best of luck, tom
Old Mar 9, 2002 | 11:40 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
could you cut off the sensor part of the O2 sensor and left the threads and body
Old Mar 10, 2002 | 09:42 AM
mckenzie's Avatar
if you had a cutoff tool, i would cut it down to the threads, and cut off the purple wire. or go to the hardware store (with o2 sensor in hand) and try to find a bolt that was the same size. best of luck, tom
Old Mar 10, 2002 | 12:02 PM
Car: 1983 Z28 Clone
Transmission: TH350
no ya see.. i dont have an o2... to stick in there.. i bought the car without manifolds.....but....today ...after searching and searching ..i finally found a plumbing cap...to fit in there. plumbing ..plug .. i mean..
rob
Old Mar 10, 2002 | 12:23 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Stick a spark plug in it.
Old Mar 12, 2002 | 10:50 AM
IROC355's Avatar
just weld it in if you don't plan on using it again
Old Mar 12, 2002 | 02:31 PM
1985_glue_factory's Avatar
Why not just use a pipe plug??
Old Mar 13, 2002 | 10:18 AM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
I believe that the above poster was correct - O2 sensors use spark plug threads. An old spark plug of the correct thread pitch would work splendidly - buzz it with a cutoff wheel and thread in!
Old Mar 13, 2002 | 09:11 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
Why dont you just get a 02 meter nad actually put a O2 sensor in there?
Kat
Night rider327
Sep 16, 2015 02:20 AM
Carlos773
23
Aug 8, 2011 12:33 PM
Token
Jun 27, 2005 12:35 PM
Xceleratemaro
Apr 23, 2005 09:52 AM
JRoy91RS
May 22, 2004 09:18 PM
