Got A Hooker!!
Old Mar 8, 2002 | 01:20 PM
TtopIroc's Avatar
Got A Hooker!!
hehe got my hooker headers and I was wondering what the air tubes are for on the stock manifolds, and do they test for that on emmissions test in georgia?
Old Mar 8, 2002 | 02:54 PM
MikeS's Avatar
Ooohh! I wanna post on this one!
Ok, I'm all settled down now. Alright. As I understand it, the air tubes supply fresh air to the exhaust gasses at whatever the hottest point in the system is. I can't remember what this is designed to reduce (NOx, HC, CO, etc)...somebody help me on that one. I do know about Ga emissions testing though. Where are you located in Ga? I'm pretty sure only the metro Atlanta area gets tested. At least, that's the area I am familiar with. www.cleanairforce.com has a little info, but not a whole lot. The visual inspections they have are pretty easy to pass. Basically they check to see if you have a catalytic converter, that your gas cap holds pressure, and that there are no obvious exhaust leaks. Other than that, nothing really matters except the gasses that come out of your tailpipes. For instance, I had an 84 Camaro with a 350, no Carter carb, no computer, no air injection system, no EGR system, and heddman shorty headers (no emissions fittings or O2 sensor). The only emissions equipment on the car was a catalytic converter. As long as it was in good tune, it passed the dyno smog test ok. Anyways, hope this helps a little. Let me know if there is anything else you need to know.
MikeS
Old Mar 8, 2002 | 02:59 PM
TtopIroc's Avatar
yea that helps alot Thanks. I live in gwinnett county, lawrenceville to be exact. where did u live?
yea all they do around here is stick something in the tailpipe and pressure check the gas cap. But I wasent sure if takeing the tubes off would affect the ol tailpipe test.
Old Mar 8, 2002 | 11:09 PM
83 MidniteZ's Avatar
They usually put the car on a dyno and take it up to 25 MPH. And check the readings. Visuals are simple to pass as was stated, just a catalytic converter check.
Old Mar 11, 2002 | 07:37 AM
MikeS's Avatar
I'm from Conyers, go to school at Ga Tech in downtown Atlanta, but am in Charlotte for a few months right now. Anyways, my guess is that you'd still be able to pass without them. At least, as long as your car is tuned up and running well. Hope it works out for you.
no green
Jan 9, 2016 09:22 PM
thekurlyone
Sep 30, 2015 12:54 PM
Chevykid810
Sep 28, 2015 12:57 PM
ssgt usaf
Sep 21, 2015 12:45 PM
Tylermcclinton
Sep 17, 2015 07:50 PM
