Can you ID headers?
Old Mar 11, 2002 | 12:07 PM
V6canvas's Avatar
Car: 1989 Trans Am GTA
Engine: Stock LS1
Axle/Gears: 3.70 9 bolt
Can you ID headers?
I am probably going buy this 85 z28. I just looked at it again and noticed that it has headers on it. It seems to then go into twin (dual) exhaust al the way back. I would guesstimate 1-5/8" primaries into 2 or 2-1/2" pipes all the way back, even two muffelers (which are really small but very quiet). I couldn't see any cats or x-pipe (the ground was wet and cold and i had on nicer clothes).
Also, there is an exhaust leak which i think is coming from the rear most passenger side cylinder (7 or 8?). There seems to be a sizable gap between the header and head.
any way to tell what kind of header i have, or does it not even matter as far as performance?
Old Mar 12, 2002 | 08:40 AM
V6canvas's Avatar
Engine: Stock LS1
noone has any ideas? Come on, i know some one here knows more about this than i do.
Old Mar 12, 2002 | 09:29 AM
BitchinCamaro's Avatar
Are they long tubes or shorties. I think hooker are the only guys who make long-tube headers. If they are shorties then they could be headman, hooker, slp, or edelbrock. SLP and headman both usally have a tag on the #1 primary. Long tubes will out perform shorties, but ground clearence is a problem. Shorties are pretty much all the same, some are better quality than others and will yeild a few more ponies, don't worry about that untill you start approaching ~400 h.p.
Old Mar 12, 2002 | 02:56 PM
V6canvas's Avatar
Engine: Stock LS1
thanx, I'll have to spend some more time under the car to check.
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
91 SrS
Oct 7, 2015 04:32 PM
Bigold4x4
Sep 28, 2015 05:21 PM
