side exhaust?
Old Mar 11, 2002 | 04:02 PM
1stgenracer's Avatar
side exhaust?
ok, i have a 91 Rs V6, i want to out side exhaust in my car, i have been doing some drawlings of my car and i think that it would look awesome with side exhaust, my question is, is there any wat that i could just keep the cat's on and then run the side exhaust from them and then out the side, i think that it would look awesome, but i need the cats because of emmissions, thanks
Old Mar 11, 2002 | 05:32 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Just be sure that you have enough clearance so you don't melt your GFX.
Old Mar 12, 2002 | 08:26 AM
V6canvas's Avatar
Car: 1989 Trans Am GTA
Engine: Stock LS1
Axle/Gears: 3.70 9 bolt
Either clearance, or some sort of heat shield. That would probly look sweet, were you thinking before or behind the rear wheel? If you put it behind, keep in mind that it will get pelted by anythink kicked up by the rear tires.
Also, make sure, if its in front of the rears, that you have enough room to get in and out w/ o burning yourself. While you may not mind, your passengers might not like getting burned/ hot ankles.
Old Mar 14, 2002 | 09:51 AM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
You probably didnt see the pic of the TA with the side pipes. Someone found that on ebay and put it in the appearance and detailing board. Not to many people here thought that was a good idea. Alot or people raging on it. Hey I didnt think it looked at that bad but well what can you do. Find a pic of a third gen with side pipes, put it in the appearance and detailing board and see what they say. But hey if it looks go to you do it, fk what other people think:rockon:
1992 Trans Am
May 10, 2023 07:19 PM
transaero
Aug 31, 2015 01:14 AM
db057
Aug 22, 2015 08:17 PM
Nj1987
Aug 19, 2015 08:26 PM
timonator
Aug 11, 2015 09:56 PM
