SLP Install Kit ques for those who have installed....
hey guys,
i have a ques. Did you all go out and buy the SLP install kit for the headers?
I am curious if you can just get the parts cheaper yourself. I already got the
fel-pro gaskets, seeing I am told they are the best for the job ( no leaking!)
anyone go out and get their own parts? and if you did, could ya list for me?
I would greatly appreciate it!
the install kit is a waste of $, all i used was...
fel-pro gaskets
ARP bolts with 3/8's head
you will need the dounut gasket's for header/y-pipe flange although i dont have them but i wish i do. you can order them from SLP when you order the headers.
fel-pro gaskets
I already have the header gaskets and the flange gaskets, I even have the bolts, but what do I need is something to protect the plug wires from touching the header? It looks like SLP includes that in thier kit but thats all I need and I don't want to buy the kit just for that.....
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
I have the install kit, but the headers bolts look cheap. They look like they would be way too easy to round off. I am thinking about buying more bolts. I also have to replace the studs. Did anyone else have to replace the studs and if so where did you buy new ones? There are about 4 or 5 studs. Has anyone used the header bolts that come with the kit?
the collector donut gasket you will need is Fel-Pro #60986..
and i had to go out and buy some long 3/8x16 bolts, 8 of them about 1" long with locking washers, and 4 of them like 2" or longer and just cut them to fit about right. and of course the header flange gaskets, Accel shortie header plugs, and cut a spark plug socket so it fits and then just use a wrench instead of socket to turn it, 90* plug wires, and some heat shielding is good for your starter wires, and then you'll need a 90* elbow piece for the AIR tubes. and i think thats about everything. if not just ask. i had the same question as you before i installed mine, and didn't get the response that you did, but i do think its alot cheaper then getting the $80 kit from SLP.
oh and i didn't use studs, since the stock ones didn't really use studs, bolts work better
good luck and take pics
The install kit is a waste of money if you're installing non-AIR headers because most of the content is related to the AIR tubes. I got the install kit in a group purchase for $25.
I used the gaskets and bolts in the kit and have never had a problem with leaks or bolts backing out in the least. I'm glad I bought the install kit.
so, what I am picking up, it that if I have the air setup I should go with the
install kit, but with non-air find my own. well I already have the header
gaskets, so, i think I will just try to get my own, unless there is something
in that kit that I need for the air. damn, I hate smog laws.
SLP's $80 install kit is a big rip off. As expensive as their headers are.....the kit should be included. I bought their headers for my 97TA (previous car) for $655, for just the coated headers and y-pipe. Then I went out and bought FelPro gaskets for 20 bucks, bolts were $10-15. Since I didn't get the kit, I had to get donut gaskets from a muffler shop, and I had to fabricate my own EGR pipe.
Just for S & G's, they now charge $782.50 for the LT1 headers
hectre13
Dec 11, 2023 08:14 AM
ambainb
Apr 25, 2016 09:21 PM
toronto formula
Nov 10, 2015 06:17 AM
hectre13
Aug 26, 2015 08:17 AM
