4" mufflex and Y pipe discussion
Old Mar 25, 2002 | 11:20 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
So.. I went from a set of headpipes made my denny at mufflex (and welded locally), that had no ground clearance to a Y pip and head pipes made together..
Either I am doing something wrong or this just won't work.
Any ideas on pipe fitment here?
I noticed, this (http://www.geocities.com/cfrios/Phil87IROC.html ) but it don't help too much..
Do these look very different to you?
http://cis.tamu.edu/~jcb9392/DCP_0006.JPG
http://cis.tamu.edu/~jcb9392/DCP_0007.JPG
http://cis.tamu.edu/~jcb9392/DCP_0008.JPG
http://cis.tamu.edu/~jcb9392/DCP_0009.JPG
did I incorrectly attach some of the pipes? There was no friking instructions to say which went where.
Old Mar 25, 2002 | 10:45 PM
LIL QIK's Avatar
Which Y-pipe is that?
Old Mar 26, 2002 | 06:47 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Y pipe for TPI and hooker long tubes
according the the mufflex web page.
Old Mar 27, 2002 | 01:48 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Here's a picture of mine. I haven't test fitted it yet. This pic is absolutely huge so be patient.
http://www.xecu.net/timsiford/DCP_0824.JPG
Tim
Old Mar 27, 2002 | 04:46 PM
Momar's Avatar
were those dents there when you got them. I imagine so. Do they line up right under the crossmember? I know that the first link you gave was to a guy named phil's web page. He said that he ground away notches in his crossmember so the pipe could be mounted higher up so he would have more ground clearance. I have talked to him via email and he seems to love his.
Ben
Old Mar 27, 2002 | 08:30 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
well the pic helped trax
thanks.. but.. i still did not get it attached complete.
For 1, i had the Y upside down.. the Y ends up being far from level (which I had not expected). But, it does seem extremly tight right at the ridge on the front side of the cross member.
It involves moving all 6pieces (the collectors hookups on mine are a separate piece) in three differnt axis to get things lined up.
And I could not quite complete it working on the ground. I hope to knock it out thurs. (I was replacing my rockers with comp promags at the same time). The rockers are done, now just to fin the ext.
Might make the dyno jet on saturday yet.
thanks again
LT1Formula
Oct 8, 2015 08:34 PM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
