how can i tell where the leak is????
Old Mar 26, 2002 | 02:59 PM
breathment's Avatar
WHen i start the car and when im accelerating at about 1\4 throttle, i hear that ticking sound that sounds like an exhaust leak, and hopefuly not alot of detonation...
i recently installed SLP headers and the y-pipe, but when i installed the y-pipe it didn't align exactly perfect on both collectors, especialy the drivers side. but i figured if I got it tight enough that it would compress the gasket and not leak. But i still have that ticking sound, I can't hear it when im in park and rev the engine, its only when im driving or starting the car.
what should i do to tell exactly where the leak is? I tried getting under it while it was running and feelign around for leaking air, but didn't feel anything, and i couldn't tell my listening where its coming from. any clues?
Old Mar 26, 2002 | 04:00 PM
BigMike92Z's Avatar
Car: 2006 Pontiac GTO
Transmission: rowing through 6 gears
if you can get up under there and look, look to see if you can see some black buildup on the new pipes anywhere, that will help you locate a leak.
Old Mar 27, 2002 | 01:03 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
I know this sounds weird and I am prolly going to get flak over it but have a friend somehow or another pour ATF into the intake or some other fluid that will burn with a nice cloud
and you will see it flowing from your exhaust leak
found a few on my rx7 when I let the motor soak in ATF all night long
though be carefull so you do not hydrolock the motor
Old Mar 27, 2002 | 07:10 AM
BigMike92Z's Avatar
or try just regular old carb cleaner to get it to smoke a little.
Old Mar 31, 2002 | 03:26 PM
Marc 85Z28's Avatar
Plug the tailpipes with a rag - if there's a leak, you'll hear it
RS Reaper
Oct 17, 2018 07:52 PM
Mark_ZZ3
May 24, 2018 01:02 PM
Reid Fleming
Oct 10, 2015 09:56 PM
aaron7
Sep 30, 2015 09:15 AM
mfp189
Sep 27, 2015 09:25 AM
