Please help me out!.....debate!
Old Mar 27, 2002 | 12:39 PM
87GTA57L's Avatar
I've been thinking of putting dual pipes coming from the cat of my car, and make them exit to the front of the rear tires. I have a few concerns in doing it up: Would the exhaust be too loud?
could I or should I try to put mufflers on? is this going to hit on the driveshaft or anything?I think it would look real neat and as for right now, all I have is just the stock exhaust system, this way would be cheaper maybe easier for me to do for now.
thanks for any help,
-87GTA57L
Old Mar 27, 2002 | 02:41 PM
darbleinad's Avatar
Car: 84 Trans Am
87GTA5.7L,
interior resonance will be fairly high if the mufflers are under the floor boards. i dont know if you are concerned about that or not. if you have stock exhaust manifolds and use 2 catalytic converters it shouldnt be TOO loud...likely still loud...but what i think is loud may be completely different from what you think is loud. but if you are doing dual exhaust you might as well put on a set of headers and two high flow cats to get max performance. doing this will make your exhaust louder.
i am planning on doing basically the same thing...running a short 2.5" dual system (no cats), right from my flowtech shorty headers (1.5" primaries) and dumping somewhere before the rear axle. i am thinking about using hooker aerochamber mufflers, but if anyone else has any suggestions, please tell me. i know my system will be loud, with a lot of interior resonance, but that is fine and dandy with me, cause i want it to be loud.
i have another question? will my 2.5" inch dual setup be too much for a modded 305 LG4 and as a result kill my low end torque? cause i dont want that to happen. i really need some answers to this question.
thanks for your help guys.
Old Mar 27, 2002 | 03:32 PM
Tas's Avatar
Tas
Go for it. That's how Grand Nationals and Monte Carlos are almost. But they exit out behind the rear tires. They have 1 cat like us that goes to 2 mufflers.
