Question about Hedman 68470 Shorties and O2 sensor
Old Apr 9, 2002 | 03:04 PM
Eric's85TA's Avatar
Car: 1985 Trans Am
Engine: 400
Axle/Gears: 3.70
These are the shorty headers without the AIR tubes or an O2 sensor. If I order the coated ones, would welding the O2 sensor bung on and drilling a hole do harm to the finish, other than what is apparent, like will breaking the finish in this spot cause it to crack out?
Old Apr 10, 2002 | 12:35 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Do any modifying before the coating. It's not so much of a cracking issue, as it is the lack of coating in the welded area. That means you'll have to either order them uncoated, have the O2 bung welded on, then get them coated; or order them with the bung and coated (I don't believe that's a problem - talk to the source from which you intended to get them).
Go Huskers!
Old Apr 10, 2002 | 02:53 PM
Eric's85TA's Avatar
Car: 1985 Trans Am
Engine: 400
Axle/Gears: 3.70
Thanks. You're originally from Nebraska, right? I found a place over in Waverly that does ceramic coating, and aside from mailing them to Jet Hot, I think that's the only way I'll be able to get them coated with the O2 bung. I did some research though, and found that the shorty Flowtech's can be ordered ceramic coated from Jeg's for just under $200, and the Y-pipe is another $100. That's almost $100 cheaper than the Hedman setup, but the Flowtechs are only 1.5" primaries. They do, however, already have the O2 fitting welded on. I know Hedman makes good quality equipment, but am not very familiar with Flowtech. Any suggestions? The engine will be LG4 with new cast heads with 1.94/1.50 valves, stock CC q-jet, and XE249 cam. The emissions crap is going into a large box in the attic. Will 1.5" primaries be enough, or would the 1 5/8 be better?
Old Apr 10, 2002 | 10:18 PM
five7kid's Avatar
Native, correct. And alum - UNL, BSME '85.
The 1.5" primaries depends upon ID or OD. My Hookers are 1-5/8" OD, which is right at 1-1/2" ID. The Hedmans on the '57, though, are 1-7/8" ID.
From what's been said about Hedman & Flowtech on this forum, sounds like Hedmans are the way to go.
Old Jun 13, 2002 | 11:02 AM
TheLG4Whore's Avatar
Car: '86 Trans Am
Transmission: TH700R-4
Axle/Gears: 10 bolt 3.73
so the 68470's have no emmissions stuff right?
Old Jun 13, 2002 | 11:50 AM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
yep no emmissions or O2 bung
Old Jun 13, 2002 | 02:16 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Another option is to put the 02 sensor into the y-pipe right after the collector. That's what I'm going to do when I upgrade to coated headers, since coated headers with an 02 bung but no air crap seem not to exist.
Old Jun 15, 2002 | 10:26 PM
highhat's Avatar
yes they do exist
My headman longtube coated headers have no air, but do have O2.
Old Jun 16, 2002 | 11:37 PM
HrdRockA4305's Avatar
Like Jim said, you can just put the 02 sensor somewhere else if you want. Mine is in the straight pipe that is where the cat used to be. I thought having it that far downstream I would need a heated sensor, but I haven't noticed a bit of difference having it down there. They Y-pipe would work too, especially if you still have a car. We just used this one because he was already fabbing the pipe, might as well not alter anything we didn't have to.
"since coated headers with an 02 bung but no air crap seem not to exist"
Yeah, sucks don't it. That woulda made the project a little easier.
Old Jul 1, 2002 | 08:17 AM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
The simplest option here is to buy a set of reducers that have O2 bungs already in them. Walker/Dynomax makes a set for just a little more than the standard reducers and just use the plugs that come with them to plug the side you don't want.
I have 3" to 2.5" reducers that I bought for like $23 locally here. Great deal for the $$$.
Old Jul 1, 2002 | 09:18 AM
12 Sec GTA's Avatar
Car: 98 Camaro SS
Transmission: M6
either order reducers with o2 bungs, or have a shop weld an o2 bung in one of the sides of the y pipe.. mine heats up fine (OE replacement $12 O2 sensor) and it's located about 3" down from where the Ypipe bolts to the header.
A shop will charge around $20 to install the bung, the bungs cost around $4.
Old Sep 20, 2013 | 08:56 PM
rwstegne's Avatar
Car: 1989 Iroc Z 5.7L
Engine: 5.7L
Axle/Gears: built 4.10s
Re: Question about Hedman 68470 Shorties and O2 sensor
Does anyone have pictures of the o2 sensor installed on y-pipe?
Old Sep 26, 2013 | 10:46 PM
GTAman's Avatar
Car: 1988 Trans am GTA
Engine: corvette 350 swap
Transmission: t-5 swap
Axle/Gears: 3.27:1 borg warner 9-bolt w/ PBRs
i have these headers. i bought them uncoated from summit. they just had black paint on them for preservation so i bought some titanium header wrap. it came with an 02 bung that i had to weld in. Took it to an exhaust shop and works great!
meeklay812
Oct 1, 2015 03:46 PM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
corey8084
Sep 17, 2015 02:56 PM
Night rider327
Sep 16, 2015 02:20 AM
Ironhead38
Sep 7, 2015 02:26 PM
