wheel house
Car: 1989 Iroc rebuild
Engine: 355 carb'd
Transmission: 5spd
Axle/Gears: 3:08 pos for a while
wheel house
NEEDED,passenger side wheel house,have quarter skin,but will need the floor cut inside of frame rail.all way back to rear panel,also need 1 2line(88-90) rear 16" wheel
Car: 83 Trans Am / 79 Camaro/dune buggy
Engine: 400 TPI/406 /1911
Transmission: WC T-5/ T-56 (looking)/bus trans
Axle/Gears: 3.42/3.73/4.56
I'm cutting up an 87 IROC and the wheel houses look really solid.Do you need both inner and outter?,as I would assume yes as you need a wheel also.I will keep you in mind when I start cutting and let you know how the outter looks behind the 1/4.
ambainb
Apr 25, 2016 09:21 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
