I have a 92 with a broken drivers side rail. This is the cast aluminum piece that is the center pivot point for the top. It mounts down in behind the door jamb where the spring tensioner allows the top to come up easy.
Email or call at 978-387-0777
Thanks,
Kurt
Thanks,
Kurt
Want a title? Post!
I have the part . its from a 92 and they are diffrent from the older 80s cars and the early 90s are the same it should have 4 bows in the roof including the windsheild bow . email if you want with an offer
ted gerlach
close
- Join DateJun 2002
- LocationNew Jersey
- iTrader Positive Feedback100
- iTrader Feedback Score(28)
- Car89 formula convert looks like a 92
- Engineoriginal 350 tpi engine
- Transmissionauto
- Axle/Gears373 10 bolt with LS1 brakes
- Liked:0 Times in 0 Posts
i should have the part, due you have a pic?
I haven't taken a picture of the part yet but do have a schematic image. I am currently moving to Maine and that is not priority one as the car is at a friends house right now. Here is the schem. The part is 1E1 it is cast aluminum and the bottom pivot in the image is near 2A
ted gerlach
close
- Join DateJun 2002
- Transmissionauto
going to check the 3 convert roofs i have i should be able to help
