Need Door Hinge
Need Door Hinge
Need a left side (driver) lower door hinge. It bolts to the car body not the door. Please message me with cost. I already have the pin and spring that go to the lower door hinge so I don't need the. Thank you
Edit. I no longer need this part. But if anyone knows how to fix the upper hinge I could use the help. The upper hinge is welded in and uses rivets instead of a pin. It is loose and I don't know how to fix it. Any ideas would be great. Thanks.
Car: 85 88
Engine: 455 Olds
Transmission: TH350
Re: Need Door Hinge
I have an upper hinge I could send you. Did you try tightening the bolts?
I don't want to try selling you something you don't need.
The only way to remove it from the door frame is to drill out the plug welds from what I can see.
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
Re: Need Door Hinge
Hotrodboba400
Dec 10, 2019 07:07 PM
