85 Trans Am fixed mast antenna wanted
Old Apr 3, 2018 | 10:52 PM
shaynecastongua's Avatar
Car: 1985 Trans Am
Engine: Chevy 355
Transmission: T5 NWC
Need entire assembly (mount nut and bezel). Preferably with cable, not required.
Old Apr 5, 2018 | 09:01 PM
beths91camaro's Avatar
Car: 87 Iroc vert, t-top
Re: 85 Trans Am fixed mast antenna wanted
I have it all- large or small plug on the cable? $35 shipped- message me if you need it.
Old Apr 7, 2018 | 04:59 PM
Here you go- the last photo you can see the difference between the large and small pin.
Attached Thumbnails 85 Trans Am fixed mast antenna wanted-dsc06336.jpg   85 Trans Am fixed mast antenna wanted-dsc06337.jpg   85 Trans Am fixed mast antenna wanted-dsc06338.jpg   85 Trans Am fixed mast antenna wanted-dsc06339.jpg   85 Trans Am fixed mast antenna wanted-dsc06340.jpg
Old Jul 7, 2018 | 11:16 PM
SirReveller's Avatar
Car: '89 'ROC
Engine: 5.7L
Hi Beth- still got these full assemblies? Any diff on the small vs large pin? I’m looking to downgrade from the (fubar’d) power antennae on my ‘89 so I suspect may not matter.
Old Jul 8, 2018 | 09:43 AM
Yes, sir, I do. I think I only have the small plug in stock right now, but an adapter can be bought for $8 or so. I may have one though.
Old Jul 8, 2018 | 11:35 AM
Car: '89 'ROC
Engine: 5.7L
Ah now I see the diff in your pic. Not much of a diff at all. Sure lemme know please if you have the adapter.
Old Jul 8, 2018 | 12:00 PM
I checked, i do not. I have the large to small ones, not the small to large.
Old Jul 8, 2018 | 01:01 PM
Car: '89 'ROC
Engine: 5.7L
Ah ok np. Not urgent so lemme know please when you next come across a working large pin assembly and I’ll buy it from you. (Still kiiinda like the power so gonna try the crown 56003151 for the balance of summer but want a fixed on hand to simplify later.)
Btw I was curious which years were small pin and which large?
Old Jul 8, 2018 | 01:38 PM
Drew's Avatar
The small pin is a later change, like 89-up or something like that.
One thing to note about the small pin, the crimped hex just before the 90* bend, just happens to fit tight in most aftermarket radios setup for a large pin antenna. So alot of the time, with an aftermarket radio you don't even need the adapter, just push the small pin plug in a bit further and it'll fit. Of course the adapters are easy to come by, they used to be an under $10 item from the car stereo section at Kmart or Walmart.
Old Jul 8, 2018 | 03:32 PM
Car: '89 'ROC
Engine: 5.7L
Thanks Drew. So I guess it is the back of the UX1 that changed slightly later on.
Beth in that case I’ll snag the remaining one. Over to PM.
Old Jul 8, 2018 | 04:28 PM
Drew's Avatar
Yep, somewhere in the 89-90 range they changed over to the small pin antenna and the one piece wire harness plug. It's not exactly a hard and fast rule, because some or most GM cars changed over early, while some trucks like my 92 S10 still had the early plugs.
For example... The 88 Bird radio on the bottom (87 build date) has the large plugs. The 91 Bird radio on top (90 build date) has the small.
Old Jul 8, 2018 | 05:24 PM
Car: '89 'ROC
Engine: 5.7L
Beauty- see it there perfectly. I think small pin will work with the vintage UX1ish JVC deck I snagged. Thanks Drew.
Old Jul 21, 2018 | 03:24 PM
Car: '89 'ROC
Engine: 5.7L
Antennae arrived with all components - thanks Beth!
Old Jul 22, 2018 | 07:50 PM
You are most welcome!
the 80s man
Exterior Parts Wanted
Apr 18, 2013 11:28 PM
87350IROC
Apr 26, 2009 04:06 AM
86IROCMIKE
May 17, 2001 10:06 PM
