WTB Power mirrors and control buttons for 92 Camaro
Old Feb 16, 2019 | 11:56 PM
LikeARock47's Avatar
I want to swap the manual mirrors to power and need to get all parts for doing so. Obviously the mirrors and control buttons, not sure what else would be needed. Trim piece for the controls? Is the wiring already there?
Color of the mirrors doesn't matter, car will be getting painted anyway. I just want the glass in good condition.
Old Feb 17, 2019 | 12:27 AM
Drew's Avatar
Re: WTB Power mirrors and control buttons for 92 Camaro
The mirror pods are the same. The support for the non-power mirrors bolt to the same stanchions as the power motor assemblies. You would need both power mirror assemblies, the switch, and the entire harness. The harness is woven into the loom with the power mirrors/power locks. So if you have power locks or windows, you'd have to likely remove the entire harness, which is one piece from one door all the way to the other. Not impossible, but a lot of fiddling for little benefit.
Old Feb 17, 2019 | 12:47 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
The Mirror Housings are not all the same,......... so your probably better off to just get complete Power Mirror Units for the left and right side top be sure there's no miss-matched parts. Besides,... if you want real good un-scratched mirror-glass the only way your gonna' get it is to buy brand new mirror lenses. Also; be sure that you get the correct Power Mirror wiring harness,...... the one made for the Camaro ( switch mounted on door ) is much shorter than the one that needs to be used for Firebird (mounted on center console ).
Old Feb 17, 2019 | 11:07 PM
Bummer, sounds like it might be more trouble than it's worth. My passenger side mirror moves by itself, slowly but enough that I can't see through it after a while. Any way to fix that? Or is it possible to add an inside manual mirror joystick on the door panel like the driver side has? I just can't believe there's no way to control the passenger side mirror from inside the car, just seems really dumb.
Old Feb 17, 2019 | 11:10 PM
Drew's Avatar
The passenger's mirror is supposed to be fixed. The glass is curved so it doesn't need to be adjusted, kind of like a blind spot mirror. Would be worthwhile to figure out why it's moving. Could be something simple to resolve.
Old Feb 18, 2019 | 12:06 AM
Interesting, thanks for the info.
Old Feb 18, 2019 | 10:16 PM
firebirddude142's Avatar
Car: 1992 Trans Am GTA
Engine: L98 5.7L 350
I still got mirrors and switch!!! Pm me
Syncity05
Jul 29, 2015 08:02 PM
RS Reaper
Nov 11, 2008 07:51 PM
compuwiz1937
Exterior Parts Wanted
May 27, 2006 09:28 AM
