Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Anyone built a strut tower brace for a carbed car?
Old Feb 22, 2004 | 07:27 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I would like some dimensions for a strut tower brace for my camaro. Different designs such as triangulated ones and ones that go straight across would be great. What kind of tubing should I use? I have a mig welder and can weld decent I guess. I also have access to tig if need be. Thanks
Old Feb 23, 2004 | 04:19 PM
jocww's Avatar
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
yea show me what you need and i can make it my guess would be just get a strait piece of tubing and cut it to the dimension and then to some plates and you should be done
Old Feb 23, 2004 | 06:26 PM
84406's Avatar
Car: 84 Z28
Engine: 355/460hp
Transmission: glide\ford 9"
I have a home made one in my 84 carbed car. I put the brackets in front of the strut bearing plate with about 3\16 clearance, then I used 1" x 1\8 square tube across. I used that because I had some but would use 1" round tube if I did it again. I had to put a slight bend in it to clear the air cleaner and then ran two pieces from the outer ends to the cowl just behind the distributor. I don't have any dimensions as I just fabbed it as I went. Not very hard at all. The difference was noticeable
Old Feb 24, 2004 | 02:52 AM
RWB____s's Avatar
Car: Z/28
Engine: 355
Transmission: Turbo 400
I believe edelbrock made one for TBI cars. If it fits that it should fit a carbed car .
Old Feb 24, 2004 | 03:04 AM
jocww's Avatar
it says it wont tho. i ve seen them work tho. what i would do is buy one trace it or get the dimensions and then work from there
Old Feb 24, 2004 | 11:01 PM
CrazyRob75's Avatar
stb
Here's one I made for my 87 Firebird......305, carbed with Dr's side mounted AC compressor.
Old Feb 25, 2004 | 12:56 AM
jocww's Avatar
crazy can u take some more pics like where you mounted it. also what is the length and what type of metal did u use, how did u bend it or did u cut and weld
Old Feb 25, 2004 | 05:19 PM
CrazyRob75's Avatar
I'll take a few more pics tonight or tomorrow when I get the chance.
It is a solid 1" steel bar (all I had kicking around). I have 2 angled pieces welded on to go back towards the strut towers. For "mounting plates", I used 1.5" wide steel and just used two bolts to secure it. Made a huge difference.
Old Feb 25, 2004 | 07:49 PM
CrazyRob75's Avatar
more pics...
Well I took 3 more pics tonight. Hopefully they are what you want as the car is squished in the garage right now.
If any wants, I guess I could make a few of them......for a small fee of course.
Old Feb 25, 2004 | 08:43 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
Looks good. Could you tell a difference with flex?
Old Feb 25, 2004 | 09:48 PM
CrazyRob75's Avatar
My Firebird is in pretty good shape for lack of rust, and the front end is also tight. After I put the bar on, I noticed on the highway the car went straighter with less "hunting" in the steering wheel. I was debating on triangulating it......but maybe when it warms up a bit.
**EDIT*** keep in mind also that it is 1" SOLID steel....not tube. It's a heavy **** and doesn't flex at all. I would have prefered to have used 1" tube.....but sometimes you use what you have available.
In total, from a single long stick of metal to cut, welded, painted then bolted on the car, I'd say it took about 4 hours.
Old Feb 25, 2004 | 10:26 PM
jocww's Avatar
that helps alot. instead of welding the angles i think im going to try and bend it
perfect pics, could u please take somemore around the bends and how you mounted it. did you have to drill holes. do you think a hollow bar will allow more flex
Old Feb 25, 2004 | 10:49 PM
CrazyRob75's Avatar
the "angles" are just metal welded together. The actual mounting points are right in front of the strut caps. I had to drill two holes per side and used washers and lock washers to make sure that sucker stays secure.
I honestly don't think the tube would really flex anymore. The difference wouldn't even be noticable.....but it would definantly be lighter.
Old Feb 27, 2004 | 09:45 PM
jocww's Avatar
right on now i have to find a tube
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
86IROC112
Aug 17, 2015 02:00 PM
1992 Trans Am
Aug 9, 2015 04:32 PM
NBrehm
Aug 5, 2015 07:57 PM
